Black running lights?
Old Feb 5, 2010 | 04:01 PM
R1ch's Avatar
Default Black running lights?
I currently have black running lights on my Camaro but they're the knock off Ebay ones that fill with humidity every time it rains. I was wondering if any of you have some that aren't crap like the ones I have and are sealed well. If so where did you get them?
thislswon's Avatar
just VHT them....
Old Feb 5, 2010 | 04:20 PM
crimson_bird's Avatar
Originally Posted by thislswon
just VHT them....
thats what i did. next time you buy a new set, just seal them with a bead of the sealer along the seams when you get them. that way you shouldnt have any problems
Old Feb 5, 2010 | 04:23 PM
SparkyJJO's Avatar
just VHT them....
Wasn't an option for me since my original was cracked.
There are two main types on ebay - crap and not crap. The crap ones seem to be the most common and easiest to find. The not crap are a little harder but not too bad.
Old Feb 5, 2010 | 04:31 PM
pace's Avatar
I just picked up a spare set of OEM ones from a junkyard and sprayed them with some VHT and clear. They clean up pretty nice if you wetsand a little too.
Old Feb 5, 2010 | 05:01 PM
99zee's Avatar
I just had my stockers sprayed. Like stated above, just pick up a OEM set and spray them.
Old Feb 6, 2010 | 12:40 AM
thecobrahunter's Avatar
Got mine off eBay, too. No problems after 3+ years. I also HVT'd them.
Old Feb 7, 2010 | 11:53 AM
Yahelou's Avatar
yea thats exactly what u have to do is put a seal around it. i was having the same trouble like u did. after i sealed them, it has been a year with no problems.
Old Feb 8, 2010 | 01:45 PM
MosesMcgregor's Avatar
I drilled some holes in the bottom corners of mine to help them drain. In the rain or after a wash they fog a little but it quickly goes away. Been running the black ebay setup for over a year with no issues.
Old Feb 8, 2010 | 03:25 PM
bene's Avatar
Trunion King
This is what I did on mine. I drilled really small hole in lowest corner of the housing where the water or any moisture will come out/drain. Works fine, its been 4 years now.
