LED Switchback DRL Size for Trans Am
I have the protectors spliced into the ground wires. (2) 6ohm equalizers, one on each side. Driver side is spliced between B/ground, passenger is A/ground. Ahead of those splices towards the sockets, I switch the A and B wires. That's how I have white drls' for the day, and amber when the lights are on.
I don't mind the questions, seems like we're learning about this at the same time. Maybe it'll help someone out later.
You might want to pick up some 18 gauge auto/marine wire. I went ahead and extended my wires some so encase I need to work on them again in the future, I'll have a little more wiggle room.
I suspended mine in the air by zip tieing one of the leads to some wire loom. Keeps them from contacting any other wires or any of the plastic in the cavity.
I didn't remember which color combo you were going for...
But remember, if you just straight hook everything up, you're going to get:
drl on, e-brake off- amber
same above with flashers- amber flash
park/headlights on- white
^^^^^^^^^flashers- white flash
switch the a/b around (my way):
drl on, e-brake off- white
^^^^^^turn sigs- white flash
park/headlights on- dim amber (very visible, see my new pics on my 3000k hid thread)
^^^^^^^turn sigs- dim/bright amber flash
good luck, and any further questions, just ask.
Just don't ask for pics of my wiring, it's a mess, and I need to go back and clean it up lol.
Here's an old factory housing (cracked, faded, pitted, nasty) next to the Depo one from Rock Auto:
The housing by itself: (it's a little dirty with bug guts on one side. I need to wash it!)
With the LED DRL:
Both DRLs:
Everything lit up:
DRL's: Amber
DRL's & blinker: Amber - Off
Headlights : White
Headlights & blinker: White - Amber
I was wondering if I could change to function to always work as if the headlights were on. Would like the DRL's to also be White and blink Amber.
