torch mod/ plastic restoring
Results:
Here you can sort of see the areas I did not bother with. If I had known how well this was going to work I would have taken before pics. The plastic also lost its rough texture and feels brand new.
After running a few test spots I found the best (for me anyways) process.
1. Clean with rubbing alcohol, this will also take off wax residue if you're clumsy like me and bump into everything while waxing
2. Lots of armorall, till it won't soak it up within 5 minutes
3. Heat gun on high (mine had 2 settings) Hold it about 2 inches from the plastic and move slowly like the OP said. Low settings heated the plastic to the point it was going to deform but not getting the desired results. You only want to heat the surface, not all the way through. This worked best for me.
Note:
If you're not careful with direction and speed you can melt high spots too much while not flashing the low areas, think of using a buffer and being careful around edges and high spots.
Now I need to clean the car up to match, it's almost too shiny!
i have yet to finish the truck (busy with school and work) when i do ill do a complete set of pictures, in the same spot so you can see before and after.
