HOW TO: Trans Am DRL Switchbacks
Old Mar 16, 2010 | 03:37 PM
contraststriker's Avatar
skytower--do you still have standard incandescent bulbs in your tails? If so, I assume the new flasher modules work with those just fine?
Old Mar 16, 2010 | 03:38 PM
MeentSS02's Avatar
Kleeborp the Moderator™
Did you just leave regular bulbs out back for the turn signals?
Old Mar 16, 2010 | 03:41 PM
skytower31's Avatar
The ONLY led bulbs I have on the car are the switchbacks. All other bulbs are stock/incandescent.
The flashers are electromagnetic so they work with both LED and incandescent bulbs.
Old Mar 16, 2010 | 03:43 PM
skytower31's Avatar
UPDATE:
My driver side switchback started acting up yesterday as I was leaving work. The white portion wasn't activating with the headlights on and the amber wasn't flashing with the headlights off. On the drive home, my gauge cluster fuse blew and the turn signals/drls were acting all kinds of weird. I'm pretty sure the driver side switchback is causing the problems. I have emailed autolumination to send replacements. I have not received a response yet but I'll be sure to keep everyone updated when I hear back from them.
MeentSS02's Avatar
It should...the flashers referenced are just electromechanical versions of the stock flashers (which are thermal)...it just simply breaks the connection at regular time intervals to create the flashing effect.
My question was more from the standpoint of me trying to do this with LEDs front and rear - with the electromechanical flashers, I had problems with the turn signals with the DRLs on - only the back would flash, and the front would stay steady (even though the indicator said that they were blinking). The only fix I could find was to go to a solid state flasher, but then it didn't click, so you had no audible signal that your turn signals were working.
I'd be curious to know the bulb life with the LEDs acting as DRLs...I know every manufacturer I went to said they would not warranty the LEDs in a GM DRL application. I just gave up and went with regular bulbs
Old Mar 16, 2010 | 03:49 PM
skytower31's Avatar
Brian @ BLSolutions has been running autoluminations switchbacks for years in his LT1 without any problems.
Old Mar 16, 2010 | 03:59 PM
Soul TKR's Avatar
Originally Posted by skytower31
UPDATE:
SIK02SS's Avatar
when did you get 'modded'?
Congrats
UPDATE:
Hmmm...*****...I already ordered a set. Well I hope it's a good set
Old Mar 16, 2010 | 04:20 PM
MeentSS02's Avatar
Do the LT1s use the turn signals as DRLs? I can't remember...either way, from the reading I did, the circuit GM uses for these apparently is known to be very hard on even regular (incandescent bulbs), and is why LED people won't warranty them in this application (at least not any of the ones I ordered in the past).
Old Mar 16, 2010 | 04:40 PM
383camaroz28's Avatar
Can we get pics when problems fix?
Old Mar 16, 2010 | 04:44 PM
  #32
skytower31's Avatar
My video was from Sunday when everything was functioning correctly.
I will be taking more pics/videos once I get my fog lights sorted out and my BLSolutions HID kit installed.
Old Mar 16, 2010 | 05:18 PM
  #33
I wanna see howd it look with hids , u get super whites right?
Old Mar 16, 2010 | 05:33 PM
  #34
Breathing Fire's Avatar
I have all LED's now except the swichbacks. I just ordered about 4 days ago so they haven't arrived yet. I will let you guys know if they work with LED's in back too. Hope that helps. I'll post up when I get it done.
Old Mar 16, 2010 | 06:06 PM
  #35
SparkyJJO's Avatar
This is because many current GM cars use a PWM signal for the DRLs, making the "effective" voltage lower (so they aren't full brightness) but it is a rapid pulsing which is hard on the bulbs (hard on the standard bulbs too, they blow more often). Our cars however don't have any PWM signals for the DRLs, it is just full steady voltage so there should be no problem using LEDs.
Old Mar 16, 2010 | 06:30 PM
  #36
skytower31's Avatar
I ordered the BLSolutions 5000k 55w HID projector kit.
Old Mar 16, 2010 | 08:07 PM
  #37
BLSolutions's Avatar
UPDATE:
Ouch! They are good about backing up their product so I would bet they will get you replacements. I had issues with a couple of their units which was minor compared to how many of their LEDs I have in my car that have worked flawlessly. Tracy is a good person to deal with over there.
The turn signals in my LT1 are also DRLs. I have the original 20 LED switchbacks which use a 5mm LED and are different than the newer SMT LEDs they use for the bigger towers. Maybe the SMTs are more volatile to voltage change than the older units.
I will pop my news ones in maybe this weekend and do some testing.
Old Mar 16, 2010 | 08:38 PM
  #38
MeentSS02's Avatar
Okay...that's what it was. I never could figure out if our cars used that same PWM scheme. I guess now I know.
Old Mar 16, 2010 | 09:11 PM
  #39
Ls1CamaroGuy87's Avatar
Do they light up white when only the parking lamp (middle) and fog lights are engaged?
Old Mar 16, 2010 | 10:02 PM
  #40
Danny2tek's Avatar
doh! I new I should have waited
