HOW TO: Trans Am DRL Switchbacks
Old Mar 17, 2010 | 12:04 AM
  #41
skytower31's Avatar
Originally Posted by Ls1CamaroGuy87
Do they light up white when only the parking lamp (middle) and fog lights are engaged?
They are white whenever the headlights are on.
Old Mar 17, 2010 | 03:48 AM
  #42
ZexGX's Avatar
I wonder if the AO set stays white when the DRLs are on and only flashes amber when the turn signals are activated? Did anybody order the Amber Off type instead of Amber White?
Old Mar 17, 2010 | 04:17 AM
  #43
contraststriker's Avatar
No--AO simply means "amber-off"--when you activate your turn signal, it goes AMBER - OFF - AMBER - OFF etc. instead of AMBER - WHITE - AMBER - WHITE etc.
The reason our cars don't work perfectly with switchbacks is the way GM wires them...different than conventional setups where with headlights/parking lights off the bulb is white.
Old Mar 17, 2010 | 10:42 AM
  #44
blackodium's Avatar
The only fix is a flasher the is electronic. NOT THERMAL. One flahser is hazards and one works the left and right turn signals. The electronic can be purchased for around 30 dollars. Do a google search.
Old Mar 17, 2010 | 11:08 AM
  #45
ZexGX's Avatar
I know what the difference is between AW and AO, just not on these cars. In a perfect world, AO goes DRL WHITE - AMBER - OFF - AMBER - OFF - DRL WHITE and AW goes DRL WHITE - AMBER - WHITE - AMBER -DRL WHITE. I kind of don't want to buy switchbacks now if there's no way to make the DRLs white. The white DRLs was a big selling point to me.
You're only partially correct... They're $5 each, not $30 each. Tridon EL12.
Old Mar 17, 2010 | 12:06 PM
  #46
blackodium's Avatar
Sorry i stand corrected. it is a no load flasher that is around 30 dollars. That is what you need to get it to work. Please read these posts.
https://ls1tech.com/forums/appearanc...-problems.html
https://ls1tech.com/forums/stereo-el...d-flasher.html
Old Mar 17, 2010 | 07:01 PM
  #47
383camaroz28's Avatar
Pics?
Old Mar 17, 2010 | 07:32 PM
  #48
So the ll552 flasher is the one to use?
Old Mar 17, 2010 | 07:55 PM
  #49
blackodium's Avatar
ebay it
Old Mar 17, 2010 | 08:37 PM
  #50
I ment pics of your car so i can see tje drls*
An u used the ll552 right?
Old Mar 17, 2010 | 10:02 PM
  #51
SIK02SS's Avatar
this says the LL552 isn't LED compatible: http://milo.com/tridon-novida-tech-i...life-552-ll552
is it wrong?
Old Mar 18, 2010 | 01:55 AM
  #52
skytower31's Avatar
Flashers are Napa EL12.
http://www.napaonline.com/Search/Det...L12_0131506168
Old Mar 18, 2010 | 02:11 AM
  #53
skytower31's Avatar
Update from Autolumination. They sent me a link to help diagnose the problem. http://autolumination.com/switchback_wiring.html Played aroudn with the troublesome bulb today and basically couldn't get it to illuminate at all. I even noticed what looks like a small burnt area on the circuit board and it definitely had a burnt smell to it. I've sent this info to them as well as a pic. Hopefully they will get back to me soon and continue to help resolve the issue.
Old Mar 18, 2010 | 10:19 AM
  #54
SIK02SS's Avatar
i wonder if water/condensation got in?
Old Mar 18, 2010 | 10:21 AM
  #55
skytower31's Avatar
Into the bulb/base? Doubt it. It is a solid formed epoxy/plastic type base. Unless it was in there from before I had it. It has been 80* and sunny each day they have been in my car.
Old Mar 18, 2010 | 10:39 AM
  #56
SIK02SS's Avatar
dunno, i can only comment on how/why my incadescent's burn out
Old Mar 18, 2010 | 11:02 AM
  #57
skytower31's Avatar
I think owning the car for 7 years my incandescent bulbs have burnt out once. :shrug:
  #58
skytower31's Avatar
Got an email from Tracy today. Gave me a RMA number to send the defective bulb back. I'll keep you all updated as things progress.
Old Mar 18, 2010 | 11:04 AM
  #59
SIK02SS's Avatar
the EL12s are cheaper from autolum than they are at NAPA. 4.99/ea at autolum and 10.99/ea at NAPA (for me at least)
Old Mar 18, 2010 | 11:06 AM
  #60
skytower31's Avatar
I wanted to get the locally incase they didn't work and I needed to return them. Also, I wanted to make sure the ones I got still clicked when the signal was activated. I don't think the autolum ones click.
