a little help with some DDm tuning HID kit
Old 04-02-2010 | 02:29 AM
ICEMAN 31's Avatar
Default a little help with some DDm tuning HID kit
So after seeing all these pics, i finally went and bought a Apexcone35w 880 5000k HID kit for my fog lights from ddm tuning. The most electronic work i have done on my car is putting in new speakers so after seeing all these wires I am wondering do i use them all or do they just add in extra just in case.
pretty much i would like to know from the people who have used these kits, What wire will i be using and which won't i be using. I am already guessing you plug "E" into "H" lol?
Also do i need to take off my bumper, I really would prefer not to, my guess is with a little tight squeezing, no?
And finally does anyone have a link to a write up, or can give me a quick one.
Old 04-02-2010 | 02:34 AM
chrysler kid's Avatar
A , B, and E are the same wire, one end is the other. i its just used as an harness extension if you need it. technically you can plug A and B into the headlight harness then plug E into H
d goes to g
c goes to f
plug the headlight bulb harness into H backwards; if you match it correctly it will not work, harness connection needs to be opposite of how its suppose to line up
there is no way to do it wrong and hurt something, just be sure not to damage the bulbs or get any finger prints on them
Old 04-02-2010 | 02:36 AM
Nacho SS's Avatar
C -- F
G -- D
E -- H
A and B slide into the prongs where your headlight used to plug it. Make sure you get the pos/neg right.
Old 04-02-2010 | 09:52 AM
ec_nova's Avatar
I took the cable that links a/b to e and yanked it out. You don't need it at all... It's for cars that aren't plug and play.
take your headlight(or foglight) connector and plug it into H then F into C and D into G.
If they're foglights, plug in normal. Headlights you will plug into H backwards.
Hang onto the a/b to e... I've already found use for the connector elsewhere and you may, too!
Old 04-02-2010 | 02:44 PM
ec_nova's Avatar
bumper can stay on. Remove the headlights and you have easy access to the fogs below. REMOVE the fogs entirely. Once out, remove the bulbs and you will see 4 screws around the base of the bulb. Loosen these up so the base can lift up a bit, and put the new bulb in and twist to lock. If it won't twist to lock, loosen the 4 screws more. Once locked, tighten the 4 screws back down.
Reinstall the fogs, plug your 880 connector into H and then (just read what I put in my last post) mount your ballasts and you're good to go. If neither come on, check your wiring. If just one comes on, turn them off and on a couple times. If there is still no difference, double check wiring.
If your wiring is ok, swap ballasts. if the problem stays with the ballast... you have a bad ballast. If it doesn't, bad bulb.
IF you constantly have to power cycle for them to both come on, get an upgraded harness and you'll be good to go.
Good luck! It's very easy just take your time.
**just noticed you have a T/A. This post refers to camaros, however my previous post is universal.
Old 04-22-2010 | 01:43 PM
tmc2k1's Avatar
I just got mine and im trying to install one side and I followed exactly what ec_nova said and they will not work. I swapped ballasts and they still wont work. Do they BOTH need to be installed for them to work?
Old 04-22-2010 | 02:00 PM
no, try hooking up the ballast to the headlights harness backwards. GM harness is wired backwards, so the connector needs to be plugged in backwards
Old 04-22-2010 | 02:43 PM
tmc2k1's Avatar
I was using them for the fog lights but it worked! Thanks man! I thought when people said to put them in backwards were only for the headlamps.
Thanks again!
Old 04-23-2010 | 11:17 AM
lol no problem. gm wired all of the lights backwards from conventional ways, either intentionally or unintentionally since they light up either way
Old 04-23-2010 | 08:26 PM
wowsers's Avatar
im sure most people already know this, but instead of flipping the headlight connector around, you can switch the pins on the them so that the clip can actually hook on to the little nub on the ballast. its not hard at all and it took me literally 2 min to do both sides. then you dont have to worry about the connectors backing off the ballasts.
Old 04-29-2010 | 02:53 PM
bill12690's Avatar
where the hell can I get a female 880 connector to wire up to A and B?? I havent been able to find one at any parts stores around here, walmart..anything. How is everybody else wiring these in?
Old 04-29-2010 | 02:55 PM
bill12690's Avatar
Just re-read this. I guess technically A and B are unnecessary.... But, I may need some more room to mount the ballasts. Just incase...anyone have an answer to my previous question?
Old 04-29-2010 | 05:03 PM
JW@JWMotoring's Avatar
The connector which connects to the stock fog socket right? I have some and all of our HID kits come with them
$6 shipped via Paypal. PM me to order
Old 04-29-2010 | 06:10 PM
bill12690's Avatar
PM sent
Old 04-29-2010 | 09:45 PM
they should have come with the kit
Old 04-29-2010 | 09:57 PM
Danny2tek's Avatar
B and A just get stabbed into the stock fog connector
Old 04-29-2010 | 10:17 PM
peterlawl84's Avatar
Why are you guys using A and B?
I followed what EC nova said in post #4 and worked perfectly...
Old 04-29-2010 | 11:15 PM
TooFast3800's Avatar
Can someone pm me if this companies HID bulbs are both 35w and 55w compatible or do I need separate 55w bulbs for the 55w ballast.
When they sell the bulbs individually they don't specify wattage.
Old 04-29-2010 | 11:16 PM
bill12690's Avatar
i didnt get any 880 female connectors with my kit.. all my other hid kits have had them, but those were 9006 low beams
