My BLS HID Install
As far as I know, my car has never been in a front end collision. No body damage or suspicious paint work on any part of the chassis. I don't know why the factory brackets were such a bitch to deal with, or why the hardware included in the kit works for others but not for me.
Regardless, I am EXTREMELY happy with the light output and the visual appearance of them when they are on or off (but still visible). Many thanks to Brian for going through the trouble of mass-producing these for us LS1tech folks!
Anyways...
Pics & captions:
Unboxing
Clear protective lens
Assembled the projector to the bracket, but didn't like the large sections of aluminum showing through, so I quickly painted the brackets after a cleaning with Windex
Cleaned the acrylic fascia with detail spray and a microfiber prior to installing the weatherstripping and protective plastic outer lens.
Wiring installed - can you spot it?
Here is where I put the fuse/relay
Velcro'd the ballasts here on the frame rails
The screws I bought as a quick fix to get the headlights mounted and aimed safely & properly. Ones included in the kit are 2.5" and hit the radiator core support, preventing the headlights from closing all the way
Before
After
Headlights closed, DRLs on
Covers could still use a little more work with alignment, but they're a lot better than before. At almost every other angle it looks perfect.
I will take some night shots later tonight or tomorrow night.
I'm still iffy on how these look, but would love the light output they produce...
on a side note... is that a custom splitter you have on there? a modified 6LE one or something else? just curious.
http://cgi.ebay.com/ebaymotors/ws/eB...=STRK:MEWNX:IT
how do you adjust the headlight cover? I havent had time to look at it, but ive been popping my hood to flip the lights every time im out at night cause my passenger side wont actually go up now.
As far as the DRL's, they seem to be around 5500k-6000k, while my lights are 5000k. FML.
Still better than **** yellow. I'm trying to find a good source for H3C HIDs for the Pilot fogs since regular H3's are too long. Once I get HIDs in those things, and some better brights, it'll be like driving in daylight when nobody is around (I just did the mod that allows you to run fogs + brights at the same time).how do you adjust the headlight cover? I havent had time to look at it, but ive been popping my hood to flip the lights every time im out at night cause my passenger side wont actually go up now.
