how to remove front bumpre
Old May 16, 2010 | 11:47 PM
01SOMSS!'s Avatar
Default how to remove front bumpre
is there a write up on how to remove the front bumper? I've never removed it. thanks...
Old May 16, 2010 | 11:56 PM
crimson_bird's Avatar
best i know of: https://ls1tech.com/forums/appearanc...on-photos.html
thats what i plan on following when i remove mine
Old May 17, 2010 | 12:39 PM
MjMaro's Avatar
It isn't too bad, I recommend taking out the headlights first. There are 3 nuts that hold the sides of the bumper cover to the front fender on each side. One bolt on the front of the fender going forward into the bumper cover on each side, 5 "pushpins" on top of the bumper cover holding it to the support, 3 "pushpins" underneath holding it to the center. Then you just have the bolts underneath hold the splash-guards to the bumper cover. IIRC that is all of the connection points. Taking the headlights out makes it WAYY easier to get the forward facing bolts from the fender into the bumper cover out.
Old May 18, 2010 | 11:00 AM
01SOMSS!'s Avatar
i have the whole headlight asembly out. thanks. I'll give it a try. do i have to remove the fender walls?
Old May 18, 2010 | 11:02 AM
01SOMSS!'s Avatar
just looked at the links. thanks guys!
Old May 19, 2010 | 02:26 AM
BFarrier's Avatar
just pull man. put your hands in the slits then pop the sides out 1 each then pull the 3 bottom out just yank out then cut the 3 top ones and get a magnet anf pull the nuts out. i just did mine in 10 min right before this post haha
Old May 19, 2010 | 02:42 AM
McNord's Avatar
Bumper or grill?
Old May 19, 2010 | 02:48 AM
^^yeah, sounds like you pulled the stock grill
