i'm surprised there is no write up
Old May 26, 2010 | 01:24 PM
King Nothing's Avatar
Default i'm surprised there is no write up
i'm surprised there isn't a write up for removing the A/C from the car. my engine is out and i'm gonna pull mine on friday (hopefully) and i was hoping to find a write up for it. i'm guessing the bolts (look like 10mm) in the engine bay hold it in?????? hey merv i know you've done this get your *** in here lol
Old May 26, 2010 | 02:23 PM
crimson_bird's Avatar
not sure why it would be in appearance/detailing...
Old May 26, 2010 | 02:30 PM
97ramsst's Avatar
Because it would make the engine bay look a lot cleaner....but to hell with that it gets hot down here!
I use to say AC was for old men and women...I guess I got old!
Old May 26, 2010 | 02:33 PM
but wouldn't there be a better chance of finding it in one of the engine related sections?
Old May 26, 2010 | 03:34 PM
this
i roll my windows down and feel the breeze . . . plus i used to work in a warehouse that was 120 so i'm very used to hot weather
Old May 26, 2010 | 03:38 PM
i wouldn't think so cause there is no performance gain from it. you drop like 35-40lbs all together, you don't gain any HP/TQ.
Old May 26, 2010 | 04:43 PM
latindragons's Avatar
What about in drag racing tech? My suggestion would be to look there.
Not a writeup, but some info...
https://ls1tech.com/forums/drag-raci...c-removal.html
Old May 26, 2010 | 04:54 PM
jb98camaro's Avatar
im doin mine this summer some time... sense my compressor is fucked.. iv had no ac sense i bought the car for two years now and ya its a bitch when its hot but i deal with it. only thing i need to do is drain the freon and i'll be good.. thats the only part im not sure about..
Old May 26, 2010 | 04:56 PM
there's the merv lol i'm pming him now
Old May 29, 2010 | 07:38 PM
so for those who've done this, did you have to pull the dash in the car to get it loose or is there something i'm missing? and who other than BMR makes the A/C delete cover?
Old May 29, 2010 | 07:57 PM
PUNISHER TA's Avatar
i started trying to unbolt it... but i ended up just tearing it out with a hammer... in pieces...
much more fun this way also
Old May 29, 2010 | 08:30 PM
so pretty much take my hammer to it? i'd like to sell this thing (doubt anyone will buy it but i'll try it lol) so if i don't want to take a hammer to it i'm pulling the front dash?
Old May 29, 2010 | 08:34 PM
sidewayz28's Avatar
if you want to do it the right way the dash needs to come out,
unless you plan on keeping the heater?
pulling the "A/C" is easy.. pulling the HVAC, the total system, is a dif. story
Old May 29, 2010 | 09:02 PM
yeah i plan on keeping the heater portion and from the few threads out there i know i need to get a dremel and cut some stuff behind the box in the engine bay . . . . so i'm still stuck with using a hammer? lol
Old May 30, 2010 | 03:25 AM
bayer-z28's Avatar
I took my AC out a while ago and then after the H/C install I realized that I'm making enough power and it was hot out at the time so why not be comfortable. Unless you are building a track car, of course. So I polished the new receiver/dryer canister and the rest of the visible parts, threw it back in and brought it down to have a vacuum test done on it and recharge it.
The removal was pretty cut and dry. Just be sure to have the system evac'd properly. Please don't release the refrigerant into the atmosphere. The EPA carries HEAVY fines for that and it seriously destroys ozone.
Old May 30, 2010 | 11:10 AM
armyboyatc's Avatar
Hey King If you pull it out then will you sell me your A/C compressor brackets, and your lines and bolts? Also Ive pulled more A/C systems off of cars than you could imagine. I used to work at a A/C shop before I got deployed. Ask me your questions and I will help you out.
Old May 30, 2010 | 11:55 AM
you mean the canister that sits in front of the passenger head right next to the battery?
i never used my AC when the car was running, you get better gas mileage having the windows down instead of using the AC . . . i tested this out a few times lol
yeah i have no problem with that.
this is where i am right now:
i've removed the five or six 10mm bolts on the exterior, now do i just take a hammer and beat the **** out of it or can i pull the dash off and pull it through the inside of the car?
Old May 30, 2010 | 01:23 PM
ok i just found this thread lol that hammer idea is lookin a whole lot better
Old May 30, 2010 | 02:10 PM
armyboyatc's Avatar
you know if you pull that blower off the fire wall then you will not have heat right?
Old May 30, 2010 | 02:15 PM
armyboyatc's Avatar
That thing has the fan that blows the heat through the vents in it. If youre willing to sacrifice heat then yea take a hammer beat the plastic off of it, take the rest of it apart from the outside and under the dash and then either buy a plate for the hole in the firewall or make your own. I like the look of one held in by rivits.
