vertical doors install HELP
Old Aug 4, 2010 | 06:12 PM
legendarysouls's Avatar
Question vertical doors install HELP
okay before i ask for help.....i got this kit for 200$ off a salvaged car and if i dont like it i plan on turnin it into a Profit So dont flip out on me guys.
ITs the bolt on only vertical door kit orig 1400$
Installing it on my 95 trans am to help show off my red two tone interior and custom double din radio..its a show car not DD.. and already got a 99 ls1 z28 to go fast in
Since there is no instructions with it..... how do i install them...do i need to take off fenders to get at hinges??......
DIDnt see a rewrite up on these obviously cuz it hard to pull off n alot ppl not a big fan
Old Aug 4, 2010 | 06:23 PM
98PurpleT/A's Avatar
You are gonna have to take the fenders off as well as extend all the wires that about all I know. It shouldn't be that difficult.
Pics of the kit you picked up?
Old Aug 4, 2010 | 07:10 PM
evilZO6's Avatar
take off door panels.
disconnect all wiring, dont cut anything, just unplug it from its piggyback connectors. back the wiring harness out of the door. You might want to label everything so you know where to put it back just 1,2,3...etc so you can match the number back up when re-installing it.
take off fenders. you will have to take off the bumper and the under siding of the bumper, as well as the inner fenders for this. Its easy don't get intimidated.
use thin wooden shivs to keep the door at its current height against the body of the car.
duct tape the door in place so it doesn't move. im talking 20-30 pieces all around the door.
unbolt the door hinge from the frame.
use a sharpie to trace the inner circle of the top bolt
remove the hinge from the door.
hold up the vertical hinge to the factory hinge's bolt openings, making sure the top bolt hole is lined up exactly where the factory tracing is.
it should fit flush, you may have to trim the inner fender its thick metal, but only stamped and not structural. get a grinder its easy and fun and wont hurt your car.
bolt the hinge down as soon as its flush.
bolt the hinge to the door.
put the wiring back in
put the door panels back on.
I have always heard you had to extend the wiring. I didn't have to on my car, not sure if its a myth or my car for some reason just had extra wiring, but im betting its just a myth or rumor. I extended one side and then realized i didn't need to, so i didn't extend the other side and it worked perfect. You will more than likely have to get new shocks because our doors are heavy and wear them out fast, get a 750 pound shock not the standard 250, those are for hondas
Old Aug 4, 2010 | 08:17 PM
1995blacktattop's Avatar
sorry, i couldn't resist
Old Aug 4, 2010 | 11:58 PM
NeedaV8foundation's Avatar
you might get sick of them, a guy at my work had them on his car and took them off cause they were too annoying to open and close.
Old Aug 5, 2010 | 12:11 AM
cfallsguy's Avatar
I do agree, guy I knew had em and i hated getting in and out of his car. But for strictly show car it shouldn't be too annoying. IMO the vertical doors or whatever you wanna call them won't look good, and I don't know much about them but will they support our doors? They are fairly heavy and without some kind of piston to hold it up seems like it won't last long.
Old Aug 5, 2010 | 12:40 AM
bad_408_vert's Avatar
A. He said show car
B. He found em for 200 bucks!
Post 3 covers it. Lets see some pics when your done!
Old Aug 5, 2010 | 12:53 AM
Irish350's Avatar
id allow for the argument that our cars are a better candidate for them, what with the length of the doors. That said i wouldnt do it; but thats what this sections all about.
Regardless, in for pics
Old Aug 5, 2010 | 01:18 AM
crimson_bird's Avatar
if i recall correctly, the doors can also be opened like normal if you choose, or vertically.
Old Aug 5, 2010 | 01:30 AM
McNord's Avatar
Not the one I've seen but then again it was only one kit & there are probably several differant ones. All I know is it was really awkward to open & close & get in & out of. But thats not that big of a deal since its a show car... Just don't let anybody see you bang your head the first few times lol.
Old Aug 5, 2010 | 11:33 AM
spikester7878's Avatar
it depends on the kit as stated before. theres a guy around me with a honda and his doors open both ways. i dont like the vert doors unless it actually opens high enough otherwise its a pia to get in and out
Old Aug 5, 2010 | 01:44 PM
Thanks for the write up they goin on sunday cuz i am striping them and sprayin them the color of the car.... to give it a lil more show quilty...
but Yes these can open both ways vertical or normal ..... and i couldn't say no to 200$....this kit is made directly for our cars so weight of our doors shouldnt hurt it..... and the entire kit only adds 50 lb to the car
Old Aug 5, 2010 | 01:48 PM
Old Aug 5, 2010 | 01:51 PM
Funkster's Avatar
For the record, that is the same amount of weight people will sweat their ***** off without A/C to save.
50 Lbs is a good chunk.
Old Aug 5, 2010 | 08:22 PM
evilZO6's Avatar
you can open them both way or you can restrict it to just up. I bought this kit becuase i was sick of our heavy awkward doors no need to elaborate we all know!! But guess what? And i dont mean to burst your bubble, but these open right into your pathway, and not any higher. I had them on for about 3 days. Took them off. Sold them. But like you said, you have a show car.
Old Aug 5, 2010 | 08:30 PM
99'CajunFirehawk157's Avatar
EvilZ06, still have that hatch?
Old Aug 6, 2010 | 04:24 AM
evilZO6's Avatar
Yes i do!!! I also have a stock Trans Am hatch hanging in the garage just in case i want to switch back. Why do you ask?
Old Aug 6, 2010 | 06:43 AM
Seem like their was a thread recently on here asking about those hatches...FWIW.
Old Aug 6, 2010 | 08:42 AM
97ramsst's Avatar
95 Trans am M6 I bet my car is Cleaner
LOL...I will take that bet!!!
Old Aug 6, 2010 | 08:59 AM
Spd-Kilz's Avatar
CONTENDERRRRRRRRRRRRRRRRRRR!
