My engine bay and engine redo - 98 TA
Well, I worked another 15 hour day, so didn't get to touch the wiring. I'm hoping tomorrow night I can get this wiring all sorted out.
I'm a little afraid of it, the bundle I need to extend has a bunch of wires that are all the same color. I guess I'll just cut them at different lengths so I know which one is which. Tonight wasn't the night, 15 hours almost straight of hard engineering and design at work my mind was in no shape for it.
But I did remember this trick setup I had made for the PD Camaro brakes, and it fit well on the TA. Would really clean up the ABS removal. What do you guys think? I'm wondering if a brake shop can make a tighter bend in a line for me, this one is kinda large, but the best I could do with my bender and flaring kit. The valve is only like $20, so I'll just buy another one and match it up so I can run the same setup on the TA and Camaro.
Guess it is too late now, what's done is done!
I cut a hole right under the brake booster and ran the wiring in there after tagging and clipping every wire.
Can't even see the wiring with the booster in there!
I then cut a notch in the impact absorber in the front bumper and ran all the wires along the channel underneath the washer reservoir. You can't see a single wire now.
And then I cut some sections of 1/4-20 rod to make a bracket for my coil pack relocation.
But I needed an engine, right?
I am NOT looking forward to soldering this many wires.
Here is the bracket I made. I'm going to trim out a little around where the positive cable attaches to avoid any arcing.
My son got happy with the permanent marker.
This project's looking really good! I can't wait to eventually start a similar one on my Trans Am! I'll be using this thread as a guid for sure when I do get around to mine!
Then my wife had me preoccupied.......
cant wait to see this when its done.
