what wires to cut to keep
Old Aug 14, 2010 | 09:43 AM
batmangixxer's Avatar
Default what wires to cut to keep
so is the black wire power? or can i keep both red ones? i want to cut the wire harness off so i just have either a black n red wire or red/red wire coming out of the power inverter
Old Aug 14, 2010 | 10:31 AM
HMERacing's Avatar
Just cut them off where your arrows are. I assume this is a 12v neon for a PC case?
Old Aug 14, 2010 | 11:32 AM
SparkyJJO's Avatar
Cut the black one near the plug. Cut the red one near the switch. Connect the black to ground, red to a 12V power source, and they will turn on. Keep the switch if you want to turn them on and off - but you may want to locate the switch inside the car. Which then you'd need to lengthen the wire between the inverter and switch.
Old Aug 14, 2010 | 01:29 PM
yes u are correct
Old Aug 14, 2010 | 01:31 PM
yes i gotta lengthen them but i was wondering does the wire i buy to lengthen them gotta match the wire for the lights? Like i was gonna get 16 gauge wire black and red ones
Old Aug 14, 2010 | 01:37 PM
AxisOfOil's Avatar
as long as the wire is at LEAST the same size as the wiring it came with you will be fine. Just don't go to a smaller wire.
Old Aug 14, 2010 | 03:25 PM
so if its bigger it will be ok?
Old Aug 14, 2010 | 08:14 PM
HMERacing's Avatar
Sure, But 1/0 is a tad overkill.
Old Aug 15, 2010 | 11:37 AM
i dont even know what 1/0 means im have the slightest clue on electrical stuff
Old Aug 15, 2010 | 12:47 PM
HMERacing's Avatar
http://www.sonicelectronix.com/cat_i...ound-wire.html
