Glass
Old Aug 27, 2010 | 04:45 PM
Egg1456's Avatar
Default Glass
What are you guys using to clean your glass so it doesnt leave streaks. Everything i use does, windex, windex vinager, glass cleaner, rainx glass cleaner. need some help getting rid of these streaks.
Old Aug 27, 2010 | 05:15 PM
crimson_bird's Avatar
i like the Armorall glass cleaner, leaves no streaks at all
Old Aug 27, 2010 | 05:32 PM
djfury05's Avatar
I use 20/20 Eagle Glass Cleaner.. works great rubs away nicely no streaks
Old Aug 27, 2010 | 05:36 PM
rob69zombie's Avatar
Stoner's Invisible Glass in the aerosal can. Bar-none the best I've ever used and you can get it at Advance Auto for around $5.
Old Aug 27, 2010 | 06:48 PM
99zee's Avatar
What are you using to wipe the glass cleaner? I use newspaper. It leaves no streaks.
Old Aug 27, 2010 | 08:16 PM
I've heard that newspaper actually leaves a light, invisible film on the glass from the ink that helps bead water better. I don't know how true it is but the best drop-off detailer in Greenville, NC uses that method at his wash.
Old Aug 27, 2010 | 09:12 PM
bigj2717's Avatar
+1 for Invisible Glass. Best stuff I've ever used. That and a microfiber towel never have any streaks
Old Aug 28, 2010 | 04:00 AM
colby72olds's Avatar
Stoners for sure. If it's good enough for pro's then it's good enough for me. Just spray, wipe, flip microfiber to dry side, wipe, and repeat.
