Cleaning up wires in the engine bay
Old Oct 7, 2010 | 10:49 PM
XtremeDime's Avatar
Default Cleaning up wires in the engine bay
Ive already done the passenger side, that was easy but now Im looking at the driver side. Does this harness disconnect at the firewall??
God I hope so. What a huge pain in the *** it would be to cut and resolder all of those...
Old Oct 8, 2010 | 01:07 AM
xXxSilveradoxXx's Avatar
My 1989 Silverado had a connector like that. It had a bolt holding it on and all the wiring connectors were inches away from it on the inside of the cab. If you don't have a definite answer by tomorrow I'll check the extra F-Body harness I have sitting at the shop and I'll let you know.
Old Oct 8, 2010 | 01:14 AM
XtremeDime's Avatar
Thanks man!
Old Oct 8, 2010 | 03:28 AM
DCC!!'s Avatar
lets see some pics tho!
Old Oct 9, 2010 | 06:00 PM
trans2000am's Avatar
that does not disconnect fyi... there is like 5 connections under the dash then you can remove it, very shitty design from GM that piece thats on the firewall the wires are basically glued together, you will most likely have to remove the brake booster also i had to
Old Oct 9, 2010 | 06:01 PM
also the wiper motor is located on the top right of your pic, you will have to remove the cowl to get to the connector or just cut an resoder
Old Oct 9, 2010 | 11:37 PM
XtremeDime's Avatar
I got impatient waiting for a response so I just went at it
Old Oct 10, 2010 | 02:05 AM
merim123's Avatar
i'm always impressed with you guys that just cut this and solder later, you must have some trick for soldering that is quick though, because that is a few hours of work to put all that back together!
Old Oct 10, 2010 | 05:14 AM
DCC!!'s Avatar
haha damnnn!! it wwould suck if a rat ate all ur numberd tape!!!
Old Oct 10, 2010 | 06:19 PM
XtremeDime's Avatar
Nope, no tricks. I ******* suck at soldering too.
