Blue Dash LEDS
Once it's out, you have to pry a couple tabs sideways on the back to get the circuit board out of the odometer. it has 3 SMD LED's on it, you need to remove them. i found it easiest to just take the soldering iron and "push" them off to the side, if you can melt both contacts at the same time with the iron, the light will just slide off.
This is what you should have:
This is after new lights are soldered in:
I actually ended up putting 3 LED's in, but it didn't make any difference, two will suffice. make sure to sand the tops smooth so the light dispersses well, and solder a small wire where the middle bulb was, i used a piece of on the LED's leads that i cut off. Make sure you put the bulbs as close as possible to the board because clearance is an issue, you'll see when you do it, test fit as you go. Here's a diagram i made up to show what needs to be done:
Be sure to just plug the odometer back in once it's reassembled, don't put it all back in the cluster, then plug the cluster back in and turn the key on to verify everything works. if not, go back and check your work, if it's good, pull the cluster back out and put it back together completely.
Here's mine:
Here's mine:
looks good, but its too much for me lol
If you still have the factory overlay, theres this film on the back of the overlay causing it to be blue even though you have white behind there.
