mix of LS1 formula/TA NEED Opinion's and your PICS!
ok guys, i was feeling a little froggy tonight, so i decides to take off my spoiler to see what im in for. only 8 10mm nuts hold it on. unplgged the 3rd brake light, and it was off. in literally 5 minutes. the hatch isnt metal, either fiberglass or plastic, didnt really take the time to define. either way, a DA sander will smooth it out fine. fill the holes with bondo, resand, and im ready to install my new spoiler. car looks HIDEOUS without spoiler tho. haha! i took some pics for you guys. it'll be more than a couple weeks now b4 i get my spoiler.... freakin regulator on my altornator went out. and ive just let it go, bc i have more import stuff you know. and its almost ruined the battery. :/ really depends on if i can sell my high rise and rear TA bumper on Craigslist tho. anyway, heres the pics.
BOBS99SS
yeah that pic of the white ta is pretty bad ***
maxplusten
id recomend fiberglassing over the holes and putting some sort of backing behind them... bondo is going to crack out eventually
nice nice, and yes LG Motorsports was the company that makes that gdfx kit I referenced, I knew it was L? Motorsports and didn't wanna botch it lmao. I'm definitely looking forward to this build thread
RacingTiger03 [>]
#32
ok guys, im totally reviving this thread from the dead.... but i have an EXCELLENT reason. lol i bought the freedom designs spoiler and got it on my TA. i personally love the way it looks.... some may not. any1 feel free to chime in. the goal here was to do a retro-throwback look, and to be unique. i nailed it in my opinion. but i know some of you following were wanting to see how this turned out bc you were thinking of doing the same. i have 18 pics of all the progess, start to finish. and i will tell all about the experience, and point out all the different ways to go, set backs to each choice and such. and ways to enhance the look.
okay, i started by completely shaving my hatch smooth. i set the spoiler on with 3m double sided adhesive tape. i moved it around to almost every angle you could imagin. what i found was the more verticle the spoiler is, the more agressive and better it looks. of course the hatch flow down at the end so this is opposite of what you want. i used bondo-glass short strand fiber hair putty to build up the back side. Now the spoiler i bought was a 1-piece. and in order to make it the correct width, it had to be slid too far up away from the tail lights. i didnt like where it sat. so i took out a 2 inch section in the middle of the spoiler. fitted it up and it looked pleasing. so i began the mounting process. i used 4, 2 inch long, 1/4 inch thick screws with 1 inch washers on each side. since i cut my spoiler in two pieces, i was able to start the srcew and washer inside the spoiler and run it thru my hatch where another washer was placed before a bolt. i did this on the outer corners of the hatch, and also 2 spaced about 8 inches apart in the middle. to help secure the front down and give me the angle i want i cut the bottom panel of my hatch under the interior panel, and drilled 6 self tapping screws thru to the front portion of the spoiler. this is necessary to pull the front down to give you the verticle angle i mentioned. now i would've like to have gotten a more verticle angle than i ended up with, but never the less i am pleased. the less up and down you have the spoiler, the more subtile it is. and ford probe looking. lol then i used about 3 freakin pints of glass-bondo filling in the spoiler in placed i wanted different contours. i filled the front side of the spoiler so the hatch didnt have the hard downward angle bc that is unappealing. even to this modification's fans. then i filled the back side of the spoiler to meet flush with the edge of the hatch. this is not required but really makes it appear much more like the heritage trans am. did some half *** body work and sanding, and i threw some red spray paint at it. lol and to be honest it looks amazing for what it is. but im getting a paint job this winter, so i figure ill let the shop do the fine tuning and such when i have it painted blue. but for now, it looks good. now show condition tho. ill post pics as soon as damn photobucket will let me login. and try to answer any questions.
i KNOW there will be hate.... if you can lets keep it to a minimum. i took the time out of my day to write this stinkin book ^^^ and help some ppl out, so lets not make me feel that is in vein.
#35
http://i780.photobucket.com/albums/y...o/IMG_0602.jpg
I really like this pic! I gotta admit the first pics of it in primer I thought it was ugly as **** then i seen the finished ones and I love it. it looks great! Props for your hard work and being different I really like it. It looks great. Congrats
#38
one thing about this project, you need a trans am hatch. formula hatch isnt compatible bc of the fact that the spoiler isnt removable. (i think anyway?)
my spoiler is done, but i will be changing the look of it a bit yet. im getting a drop kit for the front end. thinking around a 2" drop. leaving the back stock height to give it the 'raked' race type stance. it should make the spoiler appear a bit more agreesive. so im excited to see that. i have to buy rear wheel spacers bc my 295's are rubbing part of my suspension. but after that drop springs are next on the list. i will post pics after install.
#39
I didn't think I would, but I actually kind of like it. It's definitely different, which is cool.
I gotta say though WTF is up with those exhaust tips? Those have got to go!
Did you get those at Autozone? I remember a year or so ago I was looking at tips there, and a kid working there was convinced those would look good on my car. I said no, not the right style. He swore up and down they'd look great, and wanted to test them out. So we went outside and he held it up behind the car. I was like "Nope. Horrible, no way will these work".
So he wants to see. So I hold the tip up to the bumper, and he stands back and looks at it from the rear, then the side. So then he says "oh ****, man, you're totally right. Not good at all". LOL
Anyway, enough about the tips, the rest of the car is cool. I like it when people try unique mods.
#40
