My "Official" Attempt At A Build Thread
Old Jul 11, 2012 | 02:43 AM
  #201
Turnin20s's Avatar
Also forgot to add that I decided to pull my seats and interior and dye my carpet
I came across a few threads on here and decided to get some Rit fabric dye from Wal-Mart. My carpet is in really good shape and I would hate to buy some aftermarket ill fitting carpet when I can dye mine and have it fit right and be black instead if tan. Almost all of my interior plastics are out right now so I figured it was the right time. And with a spray bottle ($1), a hard bristle brush ($2), 3 8oz bottles of Rit ($3 each), and 3 boxes of RIT ($2 each) just in case the liquid doesn't make it all the way. I have under $20 and as long as it doesn't come out purple I'll be happy
Old Jul 11, 2012 | 09:35 AM
  #202
1961ba427's Avatar
That made me laugh out loud for real at work. I hope it turns out great!
Old Jul 11, 2012 | 12:43 PM
  #203
Turnin20s's Avatar
haha glad I could offer some comic relief
I also ordered a cobra shift **** since all of the decent looking GM ***** are too expensive IMO. So I'll have to drill it out and tap it the right size, but it should look 100% better than the cheap Hurst **** I have now
Old Jul 13, 2012 | 01:17 PM
  #204
Turnin20s's Avatar
Also scored up a good CL find, found a set of 3 mint firebird door panels for a good price, so tomorrow morning I'm going to pick them up.
Shift **** is on the way, black dye for the carpet is in my Yukon, I have the paint for the exhaust, all I need now is my damn rear brake hoses. Should be a fun filled weekend as usual
Old Jul 17, 2012 | 01:33 AM
  #205
Turnin20s's Avatar
This weekend I finished the exhaust and painted it flat black, ran the rear brake line from the proportioning valve to the flex hose(then ran out of ends so we couldn't finish the hard lines on the axle), filled the rear end with Lucas, filled the tranny with some crap ATF from Oreillys, filled the motor with coolant, filled the power steering, and fired it back up for the first time in a year and a half. And other than both my headers leaking at the head, my y-pipe hanging really low (needs a little adjusting), and my idle being at 1100 rpms for some reason, it sounds amazing, but loud. A little louder than I was expecting, but I need to drive it andd see how I like it.
So now I need to finish up the rear brake lines on the axle, bleed my brakes, adjust my suspension so it sits level, and find a shop that will actually give me an alignment.
Sorry for not posting any pics, but I was is a mode this weekend and got a lot of **** done and didn't snap any pics. I'll get some pics of the exhaust and hopefully some pics of it outside this weekend after it gets a much needed bath.
Old Jul 20, 2012 | 11:52 AM
  #206
Turnin20s's Avatar
Alignment is going to be next Friday, so this weekend I have alot to finish up and load it up on the trailer so I can drop it off.
Center rear axle side to side and front to back and tighten everything down
Set pinion angle
Install the brake hoses and bleed the brakes
Install new header gaskets
Adjust my Y-pipe so it isn't hanging down so low
Set the ride height at all 4 corners and tighten all the jamb nuts
Then put my interior back together and install my new shift ****
I hope I can get most things done Saturday afternoon so I can actually have a day off for a change and maybe go boating
Old Jul 24, 2012 | 01:19 AM
  #207
Turnin20s's Avatar
Thursday I'm going to run out to my parents in the morning and bleed my brakes, and adjust the ride height after the car settles again, then clean it up and load it on the trailer so I can drop it off at the shop on Friday morning. I took Friday off and I plan on getting the break-in done on the rear axle and working out the bugs that I may run into.
This weekend I got most of the list above done (except bleeding the brakes) and I cut the fender off the left hand side of our trailer and made some brackets to make it removeable. So now I can actually open the door and get out/in when its on the trailer.
Old Jul 24, 2012 | 10:08 AM
  #208
stevesfbody's Avatar
very nice. glad to see its all coming along
Old Jul 24, 2012 | 10:58 AM
  #209
brutalis's Avatar
Psh, just climb in and out of the hatch! That's what I did
Good to see some solid progress!
Old Jul 24, 2012 | 01:15 PM
  #210
Turnin20s's Avatar
HAHA been there, done that. I'm ok with that when no one else is around, but when I have to drop it off at a shop I don't like to put on a show LOL
I wish I would have taken some pics, but I had a lot to do and not a lot of time so the camera never got picked up But Friday I will have a lot of down time while my gears cool off to snap some pics, so hopefully I can get to stop at some decent scenery and get some cool pics. Then when it goes back up on the lift I'll get some pics of the exhaust and everything under the car
Old Jul 28, 2012 | 06:30 PM
  #211
Turnin20s's Avatar
All cleaned up and loaded for the alignment shop Thursday night
At Autozone getting ready to install a new power steering belt since I lost it on the maiden voyage haha
Old Jul 28, 2012 | 07:54 PM
  #212
Turnin20s's Avatar
Ordered some poly bumpstops to go on the rear shocks, going to order some 175# rear springs next week, I have to get some new v-bands for the exhaust since I broke mine getting the car off the trailer and I'm going to refit the exhaust again to get it to tuck up a little higher. Then I need to pull the passenger side header and flatten one tube a little more so it stops rubbing on the shock tower and making my dash vibrate like crazy
Old Jul 28, 2012 | 07:58 PM
  #213
__Z__'s Avatar
almost looks as good as mine
looks sharp man...
Old Jul 29, 2012 | 02:13 AM
  #214
Turnin20s's Avatar
looks sharp man...
HAHA thanks man, its come along way in the past 2 years
