My "Official" Attempt At A Build Thread
And how it looked when I picked it up...
The Mufflex kit I'm getting has a filler piece where a muffler will go so I will be able to get everything fitted up and then simply install the muffler when its available. Now I just need to return the driveshaft loop I ordered since its for a 3rd Gen and get the right one, hopefully I will have time to do that today.
Looks awesome, I'm glad I stuck with UMI, now the only thing I have left to get from them is the upper a armsTomorrow hawks3gen is getting a phone call and the 3.5" "sinister" exhaust is going to be ordered
Then all I have left is...
Muffler
Pinion Yoke
6LE Seats & Brackets
Battery Cable Kit
Belts
Its getting reallly, really close
Sorry for the mess, but heres the new UMI part
I guess worst case scenario I send back the merge and get a 4" and then get a 4" Borla.
Next Friday I'm ordering the muffler and yoke (again), then its damn close to being able to fire up for the first time in almost 2 years. And I can NOT wait to hear the new exhaust setup
Heres the specs...
1988 RCSB Stepside
355 w/10:1 pistons & stock bottom end & ported iron heads
Summit Cam 3000-6500 RPM .488/.488 lift roller tip rockers
1 3/4" 3/4 length headers that will be modified
2.5" dual exhaust w/xpipe & Flowmaster super 44s
TH350 w/B&M shift kit & 3000 stall & column shift
Belltech front springs cut for 6" drop (not cut yet)/Belltech 2" drop spindles
Rear flip kit by me/2" drop shackle
6 Lug swap up front w/4wd rear axle
20x8 Jet Co wheels w/275/40 Perelli tires
97 Dash, power/leather seats, carpet, doors, door panels, center console, overhead console
Autometer gauges
Speedway wiring harness
& Plenty more to come
Anyway heres some pics....
And my dad actually working hahaha
This weekend I'm going to start back on the rear axle and try to get something together to get the 8.8 back under the car. Then maybe start fabbing the y-pipe so I can get the mufflex installed. I still have a fw parts left to order, but that should happen in a couple weeks, I'm just going to order everything else at once.
Anyway heres the 3.5" mufflex, it has been sitting in a box in the shop for a few weeks now. Not alot of piping for $450
Heres some pics...
This weekend the 8.8 should be installed with the TA mount and I'm going to start on the y-pipe and fitting the exhaust. Its getting really close, over the next couple of weeks I should have all of my parts and hopefully be able to get the alignment done the first week of May and be driving it again
Got the call tonight that the axle was done, so my dad is gonna pick it up for me tomorrow since he works in the same town as the welder. So this weekend I should be able to make my car a roller with the 8.8 in there finally
Now I'm just waiting for parts to show up and more funds to order more.
So tomorrow I'm going to get some brake line fittings and some welding wire and see if I can get the 8.8 installed and start filling up all of the fluids. If all goes well I should get everything done after next weekend except installing the new seats.I'll get some pics uploaded tomorrow, lots of flash under the car now
I'm making my brother and my buddies jealous haha
My cruise control is now MIA as well, I melted the cable with the header and need a new cable, but I'll keep it around incase I ever want to put it back in with a new cableNow whats left...
hook fuel lines to the motor
weld LCA mounts to axle
finish rear brake line
put the guts back in the rear axle
Install the steering shaft
get a few exhaust pieces and install the pipes
do the power steering lines
paint my seat brackets when they come
install the passengers side window harness
bolt up the seats (ordering them Friday)
Next weekend we may go to a swap meet and walk around a little bit, but I think I'd rather get some more work done on my car.
Anyway heres a couple pics...
Anyway some pics...
