Removing side trim from a red firebird..
Old Mar 21, 2011 | 10:26 PM
1Psycho's Avatar
Default Removing side trim from a red firebird..
Alright, here's the deal. I want to remove the side moldings and "Formula" logos off my 98 formula but I'm worried about the paint being different colors. Anyone taken the moldings off of theirs this late and not had different colors without the car being a garage queen? If the red is a bit different underneath, any way to correct that easily?
Old Mar 22, 2011 | 01:13 AM
99'CajunFirehawk157's Avatar
Thumbs up
No I never heard of such a bizare idea......LOL
Welcome to the dance your late, get on with it, no issues on my end, YMMV.
all factory 1999 paint... molding removed last August...
Old Mar 22, 2011 | 05:21 AM
BirdsSince16's Avatar
Shouldn't be that bad. My car was white, so I prolly had less to worry about. If you really wanna do it and aren't sure, just take care when you remove them. I'm sure they can be reused if the paint is faded.
Old Mar 22, 2011 | 06:14 AM
82cetuner's Avatar
I removed them off my red Ws-6 a few weeks ago and had no problems my paint has not faded however.
I think you will be ok you can always take the one on the rear quarter off first and if its different then re apply it.
I still need to remove the Trans am but i will do that at a later date
Old Mar 22, 2011 | 06:46 AM
MTBSully's Avatar
what are you guys using to remove the side molding? Fishing line and what else?
Old Mar 22, 2011 | 08:51 AM
1Psycho's Avatar
Thanks guys, gonna get mine off this weekend then since I don't think my paint's really faded at all..Cajun, your car is clean man!!
Old Mar 22, 2011 | 09:40 AM
1badWS6's Avatar
Mine was faded as hell when I took it off and some of the clear coat was peeling too... still need to get that fixed. Either way, its not that noticeable.
Old Mar 22, 2011 | 10:45 AM
94 Camaro Z28's Avatar
My LT1 is far from a garage queen, sadly i don't think it's ever been in a garage . Aside from that, I'd say about 4 years ago i took my trim off and there was no fading of paint. As of now, GM's wonderful clear coat is starting to peel off and there is still no hint that my car had side moldings.
Old Mar 22, 2011 | 10:48 AM
19xtreme99's Avatar
Had the body shop pull mine off last fall when I had it in for some other paint work. Paint was mint underneath and no different from the rest of the car... DO IT!
Old Mar 22, 2011 | 02:41 PM
i didn't even use fishing line. I used a hair dryer to heat up one end and moved it up and down until it came loose, then I just pulled off VERY SLOWLY while heating as I went.
Old Mar 22, 2011 | 03:15 PM
1Psycho's Avatar
haha alright, good to hear guys..definately doin it this weekend then!
What did you use to get the goo off after you pulled the moldings off?
Old Mar 22, 2011 | 04:12 PM
MTBSully's Avatar
goo gone or goof off seems to work well
Old Mar 22, 2011 | 05:59 PM
1Psycho's Avatar
Cool, thanks guys!
Old Mar 22, 2011 | 06:50 PM
ZexGX's Avatar
You just had the car repainted... If they didn't take them off before repainting then it will not match at all...
Old Mar 22, 2011 | 07:37 PM
1Psycho's Avatar
theyre only painting the front bumper, fender, and driver door..color matching it to the existing paint
Old Mar 22, 2011 | 08:06 PM
ZexGX's Avatar
$5 says you pull off the molding on the driver door and fender and the paint under doesn't match, assuming they don't pull the molding before paint and reinstall after paint. Ask them if they took the moldings off or not before painting the pieces and explain why.
Old Mar 22, 2011 | 09:00 PM
1999transamls1's Avatar
my car is color coded nbm and i took mine off and it was black underneath the trans am and side moldings
Old Aug 5, 2019 | 03:30 AM
Joseph Burkhardt's Avatar
and i thought i was the only one who would have thought to do this
