Replacing headliner
Old Mar 24, 2011 | 11:49 PM
Shenlon's Avatar
Default Replacing headliner
Soon I am planning to replace my stock ebony interior carpet with aftermarket upgraded carpet and I want to change over to actual black carpet. I've seen some of the pictures from where other people have done it and I think it looks awesome. The problem is that I'll still have the lighter colored headliner and sun visors.
Has anyone taken one of the aftermarket headliners that's made out of something more sturdy than the stock headliner and tried to wrap it in leather or suede or something other than cloth? What do you guys think? I would also probably either replace the sun visors or cover the stock ones with the same material as the headliner.
Eventually I would like to remove almost all of the interior pieces and wrap them in either leather or some sort of suede-like material, but I'd like to hear some of the opinions while I'm still in the planning stages.
Old Mar 25, 2011 | 12:31 AM
94T/A5.7LT1's Avatar
I did an ABS T Top headliner and wrapped in an imitation suede. The fit of the abs replacement wasnt the best fit and took A LOT of heating and forming with a heat gun. The suede wrapped nice but was very hard to get the tight radiuses by the center bar of the t top.
Old Mar 25, 2011 | 01:07 AM
Super-Bat's Avatar
I wrapped my headliner in vinyl. Same color/grain pattern as the dash. Looks and feels great.
Old Mar 25, 2011 | 01:09 AM
Shenlon's Avatar
Nice, glad to hear I'm not the only one that has thought of doing this. Would either of you mind posting pictures of how yours looks? Also, where did you get your ABS liner that the fit was not good? If you'd rather not publish that info, a PM would be great. Thanks
Old Mar 25, 2011 | 01:00 PM
I will get pictures as soon as it stops raining. As for where I got it, I want to say stockinteriors but Im not 100% sure. Also the openings for the sunvisor mounts did not line up at all. Its nice with a little bit of work and much stronger then the stock headliner board.
Old Mar 25, 2011 | 01:48 PM
Super-Bat's Avatar
Here's an okay pic of during the process.
I left the tan dome light for the pic to show the great contrast in color (did a tan to ebony swap in the car).
The creases took some heavy negotiating but most of them smoothed out nicely.
Still may redo it over the summer. I left the old material on, and laid the vinyl over so as to give it some cushion and soft feel. But I think the old material is starting to separate and may be what's contributing to the left over ripples.
Good thing is, the vinyl can be reused. Just take your time.
Old Mar 25, 2011 | 02:29 PM
The Alchemist's Avatar
UNDER PRESSURE MOD
Definitely post some pics. I noticed the other day that my headliner is looking more gray these days than black. I may just pull it and spray it.
Old Mar 25, 2011 | 06:22 PM
Here's some it was kinda hard to get it all in one shot and still show the suede material.
Old Mar 25, 2011 | 06:29 PM
APG12's Avatar
Anyone ever try spraying the headliner with SEM?
Old Mar 26, 2011 | 07:54 AM
UNDER PRESSURE MOD
What's SEM?
Old Mar 26, 2011 | 09:23 AM
APG12's Avatar
Originally Posted by The Alchemist
What's SEM?
Paint/Die specifically for interiors. Guys use the Landau Black on interior panels and it matches perfectly. The can says it can be used on carpet also. I was thinking about trying to spray my gray headliner and see what happens.
Old Mar 26, 2011 | 09:48 AM
Shenlon's Avatar
That looks pretty slick IMO 94T. Thanks for taking the time to post the pictures.
Old Mar 26, 2011 | 12:04 PM
^ yea it was a good update to the car, just wished the abs headliner had a better fit. But with some heat and patients it turned out really good.
