Removed my body moldings...but
Now i have lines on my doors of i guess dirt or something thats in the clear coat...Has anyone else had this problem? Whats the solution?
picture really is worthless because to see the whole line i have to take from a distance and from a distance you really cant see it unless you are pretty close up..the best way to describe it is like there is dirt embedded in the clear coat...i was told wet sanding is the way to get rid of it but i wanna know if theres an easier way....ill see if i can try and get a picture
Not really anything else you can do to get rid of it. I had to wet sand and buff both of my trucks when I pulled the body moldings and decals. The clearcoat was even distorted behind the decals I got most of it out but not all of it. If you dont know where to look you cant see it, but it still drives me nuts
Simple solution.
Get some paint thinner, dip a cloth in it, and rub and rub. Paint thinner WILL NOT hurt your paint unless it's new paint and not cured and paint thinner will take that adhesive off easily.
