WOW tinting T top quote
This. Buy some tint and spend 30 mins doing it yourself, just make sure to let it dry before sliding em back into place. After I tinted mine I put them back on the car not thinking and the sides wrinkled up, but if it really bothered me I could just remove it and do it again but no one ever looks at them anyway.
Took me 30 minutes to take old tint off my back window. Hose it down in Windex with ammonia....that's why they tell you to not clean aftermarket tinted windows with ammonia. It peels right off. You can atleast save $20.
do it yourself. Go to walmart and get some 2.5% tint. I had never tinted before, and there was enough for me to mess up a few times and still get it pretty good. Follow this:
http://www.camarozone.com/tinting-your-t-tops/
Internet Mechanic
I do not assume they post shop rate per hour figures but I wager its in the 50-60 range easy.
Also to keep in mind these jobs and side windows are gravey, a one piece hatch is a major PITA and probably do not charge enough for the job so you have to make it up somewhere.
Lastly, if you can do it yourself then by all means. My brother did this for years and it was worthwhile since the cops busted his *** every other week, he got to be an expert at doing this. They always made home slash the tint when he got pulled over since it was illegal rated tint.
LS1Tech Premium Sponsor
Agreed, do it yourself! It's an easy and inexpensive mod you can do yourself and have great results!
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
Will this mod reduce the heat a bit if you drive around without the interior panels in place? Obviously it wont reduce the heat 100% but i was just curious if the heat can be somewhat bareable when the interior panels are not in the t-tops. I like the look of the somewhat all glass roof.
