FUDGE!!! Paint not sticking on caliper!!
I'm having a problem with the paint not sticking. I sanded the casting marks off the caliper with a dremel and sanded it down using 60 grit. Yes, 60 grit. It worked fine on the caliper mount thingee but the caliper itself is "bubbling" on the right side. I don't get it. I even sprayed on some adhesion promoter and again, the caliper mount thing came out perfect. Anyone with some insight??!!
Wear rubber gloves oil from your fingers will cause the bubbling. Agree with the two above clean with lacquer thinner first then sand then clean again and paint
Yes, sounds like a grease/dirt/etc issue. Strip to bare metal and clean very well! Since the caliper is cast, it could even be oil embed in the metal. There are primers out there that are more forgiving to oil and grease than others.
