Removing Side Moldings
Old Jul 16, 2011 | 11:09 AM
Midnight00SS's Avatar
Question Removing Side Moldings
I have a silver 02 SS and the side moldings are starting to fade, so instead of painting them, can i remove them easily without damaging any of the paint behind it, the car is mint shape wise, just dont wanna take the chance, has anyone ever did this before or can give me so advice? thanks
Old Jul 16, 2011 | 11:15 AM
PGUFF's Avatar
Almost everyone on here has done it. You will be fine as long as your car hasn't been repainted.
Old Jul 16, 2011 | 11:16 AM
PGUFF's Avatar
I would try to heat up the moldings or do it on a really hot day. You will still leave glue behind. Rub it off with your thumb and then clay bar it.
Old Jul 16, 2011 | 11:18 AM
No its the original paint, and its clean, but wut do i use to pry it off? i dont wanna hurt anything behind it
Old Jul 16, 2011 | 11:40 AM
ChrisRZ28's Avatar
Heat with a hair dryer and slowly pull it off. I used bug and tar remover for any adhesive left over.
Old Jul 16, 2011 | 11:41 AM
bigj2717's Avatar
You don't need to pry it just grab and pull or you can use fishing line and saw through the glue.
Old Jul 16, 2011 | 11:43 AM
*02WS6TURK*'s Avatar
Heat gun, paint thinner (for the adhesive), rags and patience. Be careful you don't get to radical when pulling them back...don't want the paint to get messed up. Took me roughly an hour 1/2 to get everything looking tip top.
Old Jul 16, 2011 | 11:46 AM
ls1jorge's Avatar
I didn't have a problem removing the side molding on a cold day, I use a butter knife & carefully started taking off the side molding, & after it was off, there was glue still on the sides, I went to autozone & bought Goo Gone, I rub it against the glue & let it soak, after that I used my finger nail to scratch off & it came off with no problems, this was before I had my car painted
Old Jul 16, 2011 | 11:50 AM
Unstang's Avatar
Heat them up, pull them off slowly. When you pull the tape off, pull it parallel to the panel & stretch the tape, it will start to pull off & it lifts a lot easier. There was write up on here about it before.
Old Jul 16, 2011 | 11:53 AM
Ok Cool thanks guys, how did all of ur paint look on the back side of the molding? can u tell the difference any dull spots? thats wut im worried about lol
Old Jul 16, 2011 | 11:57 AM
Unstang's Avatar
You'll need to clean & polish it up, but it should be fine. I've done it on several different colors of F bodies & never had a problem with the paint looking bad under there.
Old Jul 16, 2011 | 11:58 AM
bigj2717's Avatar
Just claybar and wax after you remove it and you shouldn't see any difference
Old Jul 16, 2011 | 12:02 PM
ChrisRZ28's Avatar
Mine was fine.
Old Jul 16, 2011 | 12:03 PM
Ok thanks guys, this should be tommorows project then, hopefully all goes well, its a shame cause both side door moldings are fine, but its the one on the quarter panels that are not good, so im gonna have to take all of them off
Old Jul 16, 2011 | 12:09 PM
ls1jorge's Avatar
After you get them removed post pics
Old Jul 16, 2011 | 12:13 PM
Def Will
Old Jul 16, 2011 | 01:38 PM
Mine has been garaged since day one, so there wasn't any paint fade (silver's a mild color too) and not much dirt behind the moldings.... So the paint was fresh.
Old Jul 16, 2011 | 01:59 PM
Yea mine sits outside, but im a detailer so im always taking care of the car inside out
