light up door switches
Old Jul 18, 2011 | 11:53 PM
trans_am7935's Avatar
Default light up door switches
so i have always wondered if there is a way to make the switches light up on the door, like the power lock and window up/down switches so you can see them at night time, has anyone ever done this?
Old Jul 19, 2011 | 09:08 AM
bigj2717's Avatar
There is a light bulb above it that lights them up.
Old Jul 19, 2011 | 10:30 AM
Danny2tek's Avatar
Old Jul 19, 2011 | 10:56 AM
jmurray87's Avatar
There is a really small rectangle/square area right above the switches where light comes though its a really small bulb. I can't remember the bulb number but put LEDs in there for a much better and brighter look.
Old Jul 19, 2011 | 11:07 AM
Swiat34's Avatar
I made a Thread on trying something like that but I haven't played with em since back then. I'm just on my iPhone so you'll have to search my username to find it.
Old Jul 19, 2011 | 12:12 PM
ssteven's Avatar
#74 bulb. Get a LED 3 way, wobble out the hole a bit and you will have a LOT more light going thru it.
Old Jul 19, 2011 | 03:07 PM
yea i meant like this:
https://ls1tech.com/forums/appearanc...ck-switch.html
was wondering if these guys ever finished it?
Old Jul 19, 2011 | 05:05 PM
Swiat34's Avatar
Found my old thread! I had hand painted the designs on but I think I'll get some vinyl and hand CUT the designs to mask the factory-style designs over the clear then paint the entire switch, peel the decals then clear the hell out of em!
https://ls1tech.com/forums/appearanc...buttons-2.html
Old Jul 19, 2011 | 05:33 PM
Snake_Skinner's Avatar
^ Thinking about getting a RRA-PDS Pistol or just doing some shopping?
Old Jul 19, 2011 | 07:12 PM
Swiat34's Avatar
I DEFINITELY want a PDS! But I wanna make it into a SBR. That and my damn iPhone fucked up the pasted link. Fixed it now!
Old Jul 19, 2011 | 11:01 PM
^ I like the way you think, that'd be NICE and definitely short.
Old Jul 20, 2011 | 02:37 AM
so has anybody actually finished the product with red LED lights and factory look? i would be very interested in purchasing a set of the finished product if you would sell them.
Old Jul 22, 2011 | 06:37 PM
Swiat34's Avatar
Ok I'm making some progress on my switches. Sorry I can't post pics from my iPhone tho. A recap of my previous Thread, I used a Dremel with a 1/32" drill bit to cut out the designs on the switches all the way thru. This left a hole in the middle of the switch. I covered te outside of the hole with tape and filled the inside with clear epoxy. When the epoxy dried I pulled the tape and sanded it smooth.
Now today I used the 3M Plastic Painters Tape I have and an exacto knife to cut stock-looking decals out. I'll place these over the clear epoxy and use them to mask off the part I want to glow. Later I'll paint the switches with black paint. Several coats so it blocks the light well. Then peel my little decals off and clear coat the hell out of the whole switch. I'm gonna pull surface mount LEDs from a damaged LED strip I have and glue them to the underside of the switches. Since that clear epoxy isn't white, I'll probably wire the LEDs to stay on when the car is on.
Thoughts? Ideas?
Old Jul 22, 2011 | 08:58 PM
ZexGX's Avatar
Your passenger side might be dimmer than your drivers side depending on how you wire it up, otherwise, no other thoughts or ideas from me.
Old Jul 22, 2011 | 10:04 PM
Swiat34's Avatar
^ Thats because the power the passenger side gets comes thru the drivers side first. But I plan to pull power directly from the switch. So I can use slightly less ohm resistors on the pass side to make up the difference. How many coats of paint do you think it'll take to keep light from shining thru?
