Stupid Xentec HID lights no work
however, the lil clips clip into place so im assuming they should be plugged in the correct way the first time around. Knowing this might be a polarity issue, I will flip the connectors and see how that works
btw my headlamp fuses aren't blown either
Copy & Paste Moderator
The Camaro is wired backwards from the more common orientation. It makes no difference for Halogen bulbs because they will work either way, but HID only works with the polarity in one orientation.
This is a common issue that pops on on LS1Tech often. A search would have answered this.
Try this, plug in the HID ballast wire upside-down into the stock harness socket. If that works, then just swap the pins in the connector so you can properly connect with with the lock tabs.
Yes this fixed my problem, I flipped the power connector and they light up beautifully ![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
I did do a quick google search, but the y-u-no-guy was my last ditch effort and it worked flawlessly so i should start using him more often haha
hes my lil good luck charm
