Possbile to remove drivers seat back?
Old Aug 12, 2011 | 05:21 AM
Supajut's Avatar
Default Possbile to remove drivers seat back?
Found another seat in better condition. Curious if I can just swap the backs instead of the whole unit. AKA mine has a better base and this one has a better back....
Old Aug 12, 2011 | 07:29 AM
LS14EVR's Avatar
Sure. Shouldn't be an issue.
Old Aug 12, 2011 | 02:56 PM
VIP1's Avatar
Copy & Paste Moderator
Yup. Also passenger and driver seat bottoms are the same except for a threaded clip that needs to be swapped from one side to the other. At least that is true for the Formula seats and I think its the same situation with the Camaro seats.
Old Aug 12, 2011 | 03:19 PM
Supajut's Avatar
WOW, great to know. Thanks for the info guys!
Old Aug 13, 2011 | 06:52 PM
guy7bmwm83's Avatar
Those rear bottom seats are super easy to remove. One bolt and thats it. When I first removed mine, I found a bunch of trash from the last owner. Be prepared for what you may find if you have never removed them. I found melted candy, a fake finger nail, an old receipt, a tax document, blonde hair, and other junk.
Old Aug 13, 2011 | 07:06 PM
VIP1's Avatar
I think he's talking about the front seats, not the rear.
Old Aug 13, 2011 | 09:17 PM
01ssreda4's Avatar
Two bolts on one side (13mm I think) and one torx (T50 I think) bolt on the other and the top and bottom separate. Center console will likely be in the way so the seat will probably have to be pulled out of the car first.
Old Aug 13, 2011 | 10:36 PM
rubeng's Avatar
Yes 2 bolts I believe and you can swap them out. It is easier to remove entire seat from car first. Start by removing the 4 nutz that bolt the seat down. Then remove 2 screws by headrest to release seat belt. Seat comes right out. You cannot swap drivers with passenger because of the latch. If you decide to swap driver and passenger bottom seat covers, will not fit perfect but can be done. Passenger will have an open slit from the electronics driver side, but will face middle console.
Old Aug 14, 2011 | 07:32 AM
Supajut's Avatar
Thanks again for the knowledge. Much appreciated! Yes, just want to swap a drivers front seat back out. Will remove both and go from there. Thanks LS1Tech
