Ask a Professional Detailer
Headlight restoration: What is a tried and true way?
I done a good wet sand with the usual high grits and polishing compound, but they still turn to crap quite quickly in the AZ sun.
I have another car that had a true pro detail before we got it. It seems to have a clear coat of some sort on the head lights. It's been in the sun way more then my car and they still look way solid and not hazy one bit.
I found some good "looking" stuff (SprayMax aerosol).
But, I don't want to just test stuff on my near mint z.
Thanks in advance. . . . .
Jeff you're the man for starting this thread
Cool, just what I figured.
Any retail places sell any of these?
If not, which online place has em'?
Thanks Ryan! Just want to help out my community! I really do love this stuff!
Retail, no. In fact Opti-Coat isn't available to the general public, but you can get Opti-Coat 2.0 online as well as the other two.
Cheapo lights almost never line up even, so if you want cross-eyed headlight beams, go for it.
You could have a bodyshop re-clear them, or you could get some spray on clear and do it yourself for cheap.
So, does it appear like a clear coat?
Is it thin? Seems like a rock hard clear coat.
Last question I had was, what is your opinion on using no rinse or waterless wash products like Optimum No Rinse or Ultima Waterless Wash?
Is this a good substitute or bad idea? I'm talking about a clean car that has light dust build-up after a day of driving.
Glad I can help you guys out
I would suggest any trim shine product that doesn't contain silicone. Silicone will give a false shine, as its the silicone that does the shine and it doesn't soak in to the plastic, so it goes away fast. It also will dry the plastic out more (though there is debate on that subject).
Black WOW is a good one, and also 303 Aerospace protectant, as they both contain UV blockers which will help the trim look good longer. You can also use Zaino Z16, diluted to a low shine or a full strength. Meguiars Professional Water-Based Dressing works nicely too, but doesn't last quite as long.
I would advise against dressing running boards or rear steps on tailgates as they can be slick and you don't want a family member (especially a child) or friend to slip and fall and hurt themselves.
It's a little pricey, but a little goes a long way, lasts long and is by far one of the best products I ever used.
