Ask a Professional Detailer
Old Sep 26, 2012 | 11:23 PM
  #1861
LilJayV10's Avatar
MF and mothers aluminum polish would be the least aggressive.
Next would either be a more aggressive polish(I don't know what that is)and a MF
After that would be mothers polish and 0000 steel wool.
Obviously after the mothers(i'm using this as an example)and the steel wool you would need to step down to a MF and the same polish and/or a finer one like mothers billet.
There are so many products out there its hard to say what exactly what you should use. Sometimes a combo that shouldn't work does.
Old Sep 26, 2012 | 11:28 PM
  #1862
LilJayV10's Avatar
I know Jeff use to recommend using the polish w/ steel wool but changed his mind to polish/MF towel.
However I don't know EXACTLY what circumstances where made in the decision.
Yes polish and steel wool is aggressive but sometimes its the only thing that seems to work.
What finish(polished aluminum, stainless, chrome)will play a big role in what you decide to go with.
Old Sep 28, 2012 | 09:12 PM
  #1863
chadroosa's Avatar
just wondering if you have used any of griots polishes/sealant/wax.. i have it and it works great... but was wondering how it compares to other brands... thanks
Old Sep 29, 2012 | 06:29 PM
  #1864
dabest09's Avatar
I already tried the MF/mothers mag and aluminum combo. Worked great for cleaning and making the tips very shiny. However, did nothing for the fine sanding marks. Maybe I should try the steel wool next...
Old Sep 30, 2012 | 10:33 AM
  #1865
ldyzluvdis06's Avatar
my brother has a black gmc seiarra. the other day there was road construction going on. they were redoing the stripes on the road. he had to drive through and now both sides are covered with yellow road paint. i tried gas and mineral spirits to remove with no avail.
any help with this issue?
Old Sep 30, 2012 | 11:35 AM
  #1866
Conrad's Avatar
I'd be pissed and would take it to the city and have them deal with it.
Old Sep 30, 2012 | 11:47 AM
  #1867
GoFast908Z's Avatar
Road paint is a nightmare. You may have to have the city pay to repaint the truck. Road paint is designed to last YEARS of the most strenuous abuse.
There was a guy on the M3 forums this year who got hit with the splash from a large container of road paint on the freeway. $25k worth of brakes, body kit, carbon fiber, and suspension all ruined by the road paint. They totaled out the car.
Old Sep 30, 2012 | 07:32 PM
  #1868
So there is no way to fix it at home? it's not a huge glob like the M3 story. it's splattered like oil would splatter on the side.
Old Sep 30, 2012 | 07:49 PM
  #1869
GoFast908Z's Avatar
The M3 wasn't a glob....it was splattered everywhere at freeways speeds. There is no easy fix.
Old Sep 30, 2012 | 08:57 PM
  #1870
Conrad's Avatar
Pretty sure the only option would be wetsanding, but that's up to you...take the car to the city and have them pay to fix it.
Old Oct 2, 2012 | 03:00 AM
  #1871
GoFast908Z's Avatar
Yes, but I was not impressed by them. I'd give them a C+ compared to other products from Meguiars and Menzerna.
Old Oct 3, 2012 | 03:05 PM
  #1872
ThirdgenTa's Avatar
Try goof off. I just removed overspray from an entire truck with this stuff. You will have to buff it afterwords though.
Old Oct 5, 2012 | 07:05 PM
  #1873
LilJayV10's Avatar
What about using mineral spirits?
Old Oct 7, 2012 | 08:54 AM
  #1874
99'CajunFirehawk157's Avatar
Just a quick Blackdiamond question: I purchased my last large bottle of Wet Diamond and on the bottom its dated 4/2011 so I assume its the old version? Anywho; Apply, let dry apx hr to hr and a half, remove then followed by 2nd coat after first cures for 24 hrs, sound about right?
Old Oct 7, 2012 | 12:35 PM
  #1875
GoFast908Z's Avatar
looks right to me
Old Oct 7, 2012 | 01:32 PM
  #1876
LilJayV10's Avatar
Jeff,
What's your opinion on using the counter weight on the PC7424XP? It says to use only with the 5.5 pads. Have you noticed an improvement using the weight?
Old Oct 7, 2012 | 03:14 PM
  #1877
GoFast908Z's Avatar
Yes definitely keep that weight on
Old Oct 10, 2012 | 10:43 PM
  #1878
LilJayV10's Avatar
Thanks for the tip. I will be sure to keep it on.
If we could, could we talk about cleaning the interior? I know its been brought up a few times through out the thread. I know Folex and a few other products have been mentioned. I guess I'm looking for a little more, like the depth of information that has been covered with paint correction.
With interiors, like exteriors, there is no one solution for cleaning/correcting every problem. From the countless hours I have spent on Autopia reading about interiors there is just as much if not more technique/knowledge than exteriors.
I know the thread has stalled a little bit, so I was wondering if we could change the direction somewhat.
I doubt that Jeff gets the Caravans will soda all over the inside of it but I would like to be able to break down what products/techniques you use for different types of stains.
Old Oct 11, 2012 | 12:31 AM
  #1879
AWDTBSS's Avatar
I'm sure he will post it up, but he did some crazy bad small suv a while ago. Took out the seats the whole deal to fix it. I can't remember the name of the thread tho
Found it
http://www.norcal-lsx.com/forum/showthread.php?t=76378
Old Oct 11, 2012 | 07:00 PM
  #1880
LilJayV10's Avatar
Found it
Holy **** that was bad. For what it cost that customer to have that done, it would been cheaper to buy a new KIA.
