Making a gauge pod need some help
He took a stab at it the other day and he covered his rendition in fiberglass but I guess there is some kind of reaction that maybe causes the glass to heat up a little and it looks like it maybe melted or distorted the foam. I took one of the foam blocks last night and carved it to what I want it to look like. What would be the next step to ensure when it's being wrapped with fiberglass it retains the same shape or should I be making this out of something else?
If not, try and put some thicker cloth over the foam and glue/staple that in place and see if it will adhere. It's kind of hard to explain over the computer, but I will try and make a little drawing if need be.
Won't the resin seep through the cloth and cause the same effect, perhaps not as severe? Unless, of course, you used a dense fabric.
I've always used clay for 'glassing, so am not entirely sure as to the exact issue you're going through. But, in essence, the resin does tend to heat up. The severity of the heat depends upon the amount of resin used.
You could always try coating the foam with some clay. Just wax it before laying the glass. That way you can get into every nook and cranny without worrying about wrinkles and uneven deformities.
I'm not a pro, so I may be wrong on a few things. I've only ever used it for a few projects, but nothing significant.
Regards,
Ryan
