Painted my BRAKE MOTIVE rotors
I was going to paint them with more red but I thought it would be a overkill so I just added a little red. anyways here you go. Yes I got the idea from a guy on here that powder coated his rotors for his show car.
[IMG]
[/IMG][IMG]
[/IMG][IMG]
[/IMG][IMG]
[/IMG]
I need to clean them up a bit but I'm sure the break pads will do the rest lol
[IMG]
![](http://i1100.photobucket.com/albums/g418/zeesnutts00/2011-10-28_151224.jpg)
![](http://i1100.photobucket.com/albums/g418/zeesnutts00/2011-11-09_143620.jpg)
![](http://i1100.photobucket.com/albums/g418/zeesnutts00/2011-11-03_151547.jpg)
![](http://i1100.photobucket.com/albums/g418/zeesnutts00/2011-11-09_143850.jpg)
I was going to do them like this but again thought it would be a overkill with the red. I did a photo shop of them and NO I didn't end up painting them like this...
[IMG]
[/IMG]
[IMG]
![](http://i1100.photobucket.com/albums/g418/zeesnutts00/2011-10-25_145751.jpg)
What kind of paint did you use? If its not heat paint its going to flake right off. If it is heat paint I dont see it lasting long. Brakes get VERY hot, and that paint might bond to the backside of you wheel and make it difficult to remove.
I like the idea, but I think powdercoating would hold up better/longer for something like this.
high temp engine paint and yes I know this wont last but I wasn't trying to pay a lot of money to have them powder coated. Next time I get a better break set up then I might powder coat them. I also used high temp clear as well.
A buddy of mine just did this on his lifted square body that he has built himself and gives a special touch to everything he does on it. He painted the hats just like you did with heat paint and within a month it has already started to flake.
![Sad](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_sad.gif)
Even the paint on the hats may flake off. Like I said brakes get more hot than what people think. Im not knocking what you did in any way so dont take it the wrong way.
A buddy of mine just did this on his lifted square body that he has built himself and gives a special touch to everything he does on it. He painted the hats just like you did with heat paint and within a month it has already started to flake.![Sad](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_sad.gif)
