Change 98 odometer lighting color
Old Dec 13, 2011 | 07:53 PM
InfernoTA's Avatar
Default Change 98 odometer lighting color
Has anyone ever changed the color of the odometer lighting on a 98 firebird? They must be different on a 98 than 99-02 becouse everwhere I read they require 3mm led's. Mine has a161 in from the factory. When I put an led in it still shines orange-red.There must be some kind of film over it. Has anyone ever removed this?
Old Dec 14, 2011 | 11:41 AM
InfernoTA's Avatar
Anyone?
Old Dec 14, 2011 | 01:53 PM
Alex41's Avatar
There is a red translucent film back there that sits between the light and the "glass". I took mine out and used some plastic stock I sprayed transparent blue to make mine light up blue. It really didn't work all that welll, plus it was difficult to see during the day time.
Old Dec 14, 2011 | 02:01 PM
HibachiZ28's Avatar
Yah I tried to change the bulb colors to blue LED's and it was fail fail fail. I've done it on several vehicles and never had an issue. That damn film is a royal PITA. Better to just deal with it as it is.
Old Dec 14, 2011 | 06:04 PM
SparkyJJO's Avatar
I know it can be done, I've seen a pic on here of someone's car after he had done his, but I don't know how he did it.
Old Dec 14, 2011 | 06:59 PM
HibachiZ28's Avatar
Those who have done it have mostly all purchased them from 6LE, Gauge Works, and other companies. At least for Trans Ams. I know on the Camaro it's a bit easier? Try search.
Old Dec 14, 2011 | 07:00 PM
HotWhipT/A's Avatar
Their used to be a company you could send your gauges to and they would change the color to whatever you wanted. I know for sure I've seen it done in blue. I think they used to be a sponsor. I thought it was ledgauges.com, but I don't see it offered.
Old Dec 14, 2011 | 07:10 PM
HotWhipT/A's Avatar
I was right! I had to get into their site a back way, but here it is.
http://www.ledgauges.com/id26.html
Stole these pics from member 2000_SS on a large thread of his
BEFORE:
DURING:
FINISHED:
Old Dec 14, 2011 | 10:41 PM
SparkyJJO's Avatar
I know you can change the LEDs. But what about the film itself? My 98 actually had a regular bulb and red film, I know newer ones (99+ I think) used LEDs like you showed there but I'm pretty sure still have the red film. *edit* or maybe not?
Old Dec 14, 2011 | 11:22 PM
HotWhipT/A's Avatar
I don't know about you. It would make sense that you have a film if you had a regular bulb. It doesn't make sense that they would use a regular bulb for the odometer, especially for just 98. I've heard of a red film on Pontiac's gauges, but the odometer doesn't have a film. Correct me if I'm wrong, but Camaros have a red odometer too. I've already consulted a Trans Am owner that has a blue odo and all he did was change the LED's....their was no film on the odo. Whatever color LED you put in is the color you odo will be.
BTW: Ledgauges doesn't seem to exist anymore, at least since about 2008 it looks like. Emails don't work either. I talked with 2000_SS as he did his blue odo in late 2010. He bought his 2 3mm blue LED's from superbrightleds. In fact, this is the only one they sell that fits the bill. http://www.superbrightleds.com/morei...-2000-mcd/305/
He also said going with 3 LED's made NO difference in brightness and that the 2000mcd LED's they sell were plenty bright. I was tempted to go with brighter LED's elsewhere, but I'll try these out first.
Old Dec 15, 2011 | 01:50 PM
InfernoTA's Avatar
I know It doesnt make sense but after 98 there were changes made. I am aware that on the 99-02 they were leds. On my 98 I can twist out the bulb and shine a light in and see the orange film on the back of the odometer,
Old Dec 15, 2011 | 09:43 PM
SparkyJJO's Avatar
Yeah I know it sounds weird but trust me, I had my cluster out of my 98 when I put LEDs in for the number lighting and there was a regular bulb in mine.
Old Dec 15, 2011 | 10:47 PM
HotWhipT/A's Avatar
Bummer. Well this thread reminded me of doing this. So I torn my gauge cluster out and its all apart awaiting LED's. I'm going to change every LED to white. Their is no film on the gauges over any of the 15 LED's. BTW, the turn signals have a green film and use regular 194 bulbs. The high beam has blue film and also a 194 bulb.
Old Dec 16, 2011 | 11:10 PM
nightmarechevy's Avatar
My 98 Camaro had a 194 bulb behind the odometer and a red translucent film behind the odometer. I took the film out and put in a 5 smt led 194 bulb in and made mine blue.
Old Dec 16, 2011 | 11:24 PM
HotWhipT/A's Avatar
Was it a strip of film or something difficult to remove? Good to know!
Old Dec 17, 2011 | 01:46 PM
Strip of film.
Old Dec 17, 2011 | 04:51 PM
DaRReLL's Avatar
Can anyone confirm this?
****!!! I never even looked at mine when I put red led's in...
Old Dec 18, 2011 | 03:09 PM
HotWhipT/A's Avatar
All he did was put this in
You can see from post 14 that a 98 cluster has a 194 bulb. That one replaced the 194.
Old Dec 18, 2011 | 04:35 PM
TORK?'s Avatar
I thought the Pontiac clusters didn't have a removable film in the sense that you "peel" off some plastic. Rather it was kind of painted on and had to be tediously removed with acetone or nail polish remover and qtips. I thought I saw a thread about it a while back.
Old Dec 18, 2011 | 05:03 PM
HotWhipT/A's Avatar
There is, by that I mean it's impossible to remove cleanly. It's only where the needles sweep over. I'll post a picture later
