T/A reverse light fix
Old Feb 16, 2012 | 10:33 PM
trans_am7935's Avatar
Default T/A reverse light fix
so what i am trying to do is get the clear cover off the reverse light housing so i can get inside. i was washing out all the dirt with some hot water and the inside reflective stuff for the back up lights just peeled off! so i want to get in there and re-paint it with silver reflective paint. has anyone done this or know how to? i have a pic of the drivers side in good condition and the passenger side all peeled off:
drivers side...good
passenger side...bad. it is hard to tell cause of the lens housing and the condensation in there, but the reflective stuff inside is peeled off
Old Feb 16, 2012 | 11:09 PM
ANTICOP RAM AIR's Avatar
I believe you have to bake them and then separate the front from rear housing... kinda like the camaro guys to when they do whistler mod... If you do it, post up a How to... Ive been wanting to design my own sequential tails but dont wanna ruin a 300 set of tail lights... haha
Old Feb 17, 2012 | 08:08 AM
well my brother is sending me a set of 98-02 T/A tail lights for free so that sounds like a good idea to me. does anyone have a link to the camaro mod so i have an idea how to bake them, idk if these big *** tail lights will fit in the oven
Old Feb 17, 2012 | 12:53 PM
The fit in my oven.. bake them at 200 for 3-4 minutes at a time....you dont want to liquify the glue just make it pliable. Also, DO NOT put it directly on the oven rack....put them on a pan and prop them up with a wooden spoon, block or something.. dont let the outside touch anything... just search "whistler how to" there are dozens of threads on how to do it... a strong metal putty knife is what ive used before.. a 1" blade or a large flat tip screwdriver... once they start to come apart, just keep pulling with smooth even pressure... if the glue gets hard, put it back in the oven... and watch it...... I wanna see if this works on those tails...
Old Feb 17, 2012 | 02:53 PM
sounds good to me, i will try this, and see if i can get it in the oven sideways. i am gonna look up the whistler how to first then i will get on it when my replacements show up
Old Feb 17, 2012 | 06:41 PM
Swiat34's Avatar
At 200° you'll have to bake for 10-15 minutes. Just check in em every 5 to make sure they're not getting soft or deformed.
Old Feb 17, 2012 | 07:08 PM
SparkyJJO's Avatar
I didn't think you could bake open the tail lights
Old Feb 18, 2012 | 12:15 AM
transam5.7lt1's Avatar
They will come apart with heat and prying on them... you risk braking them at the edges.
Old Feb 18, 2012 | 11:53 AM
ZROCWS6's Avatar
Ya I didn't think it was possible to bake open taillights either. Interested to see if that works.
