dash panel respray
Old Jun 18, 2012 | 07:49 AM
toplessHO's Avatar
Default dash panel respray
My 97 upper dash is cracked
Ive found a replacement thats 2000+ color
I want to change color to the 97.
anyone have the paint code for it in SEM or something thats compatible with plastic.
Old Jun 18, 2012 | 08:27 PM
Raleigh TA's Avatar
Is it charcoal?
Old Jun 20, 2012 | 12:44 PM
toplessHO's Avatar
not sure if its charcoal or graphite
what ever color 97-99 is
I have a 2000+ one and its black.
The one I need is more of a grey,which is why I want to recolor it
Old Jun 20, 2012 | 08:40 PM
maxplusten's Avatar
ill warn you, make sure your prep job is beyond good or youll ruin it. I scrubbed on mine for hours and the SEM still cracked and flaked
Old Jun 20, 2012 | 09:19 PM
Raleigh TA's Avatar
SEM site says 15303. I just used a surface prep spray and have had outstanding results. I did my dash, dash cover, and several other pieces when I converted from graphite to ebony. I bought a bunch of ebony parts from a friend's wreck, and have even sprayed some of those due to scuffs. I am 100% sold on SEM after being very skeptical to try it. I use the satin clear coat to reduce gloss and protect the finish. Nothing but good things to say about my experience. I even successfully dyed the trunk flap piece, so it is not just for plastic and vinyl. Don't expect the color to match perfectly, even the stock GM parts vary, just look at your upper and lower console parts.
Old Jun 21, 2012 | 08:48 PM
shr00m-dew's Avatar
15303 (Graphite) is a little too light/not enough blue to the grey. If you've coated most parts, it matches well. If you're trying to do a one off or small piece, it will look different.
But... 15303 is the closest they have. Boltasoft had some vinyl in their Sierra line that was a 95% match (color, shine, color shift with different light), but it's been discontinued. I've got some different samples on order to try and find an alternative.
Kevin D.
Old Jun 21, 2012 | 09:22 PM
toplessHO's Avatar
yea that armoral is bitch to get off
my final prep for plastic or vinyl is a wipe down with lacquer thinner.
I think Ill use bulldog too.
Old Jun 21, 2012 | 10:13 PM
Raleigh TA's Avatar
I have used Bulldog on some other parts with standard spray paint, but never felt a need for it with SEM dye.
Old Jun 22, 2012 | 06:02 AM
maxplusten's Avatar
i didnt have any problems at all on the actual dash but it seems like that plastic holds that oil and grease alot better
