Double Checking - What Flashers for LED/Switchback DRL's?
Old 07-24-2012, 05:27 AM
98 WS6's Avatar
Originally Posted by SparkyJJO
Turn signal flasher and hazards flasher. Two separate units. Probably a good idea to replace both if the stock hazards flasher doesn't work with LEDs, in case you need your hazards for anything.
Dammit. I just bought one EL12 flasher lol.
Old 07-26-2012, 12:23 AM
CamaroRick's Avatar
my stock flasher works with just front switchbacks, the turn sig flasher does not, it stays lit up amber when the turn sig is on.
pretty sure you just have to change the turn sig flasher
Old 08-07-2012, 10:24 PM
Conrad's Avatar
Can't find the EF32RL flasher. Someone please help.
Old 08-08-2012, 05:16 AM
Tbird232ci's Avatar
http://www.bulbtown.com/EF32RL_ELECT...R_p/ef32rl.htm
Old 08-08-2012, 09:31 AM
exodus_gs1's Avatar
Damn now I wanna do this, at least I found a thread with info.
But did yall switch to clear lenses?
Old 08-08-2012, 02:45 PM
mySStery_machine's Avatar
Ok, I have LED in the rear for most of the lights and will be getting the resistor in and an LED for the turn signals. I'm actually going to swap the whole set of rear LEDs to a better light pattern type in the very near future. I did change one flasher under the driver knee panel when doing the rears and everything is fine. I would like to complete the front as well and even change to switchbacks in LED form. Am I understanding correctly that I will need not only all new LED lights for the front 194s but LED switchbacks and then TWO of the new flashers that were suggested and linked to make the whole system work? We could get together on a GP from a LED distributer for the best switchback out there and look into saving some cash if we all get it together. Just an idea...
Old 10-09-2012, 09:03 PM
KJZ28's Avatar
I agree, I would like to look into this.
Old 10-11-2012, 11:06 AM
sjsingle1's Avatar
https://ls1tech.com/forums/appearanc...completed.html
is it really that hard?
Quick Reply: Double Checking - What Flashers for LED/Switchback DRL's?
