HID's, projectors etc....
Just wondering if any one know of a good HID or projector kit, is it plug and play, how much fabrication am i looking at etc.
Yes i did do a search but didn't find the answer im looking for.
Thanks.
http://www.blackbirdlighting.com/93-97.php
http://www.hidplanet.com/forums/show...oto-Mini-H1-V5
Don't get me wrong. The Hella 60's/Moritmoto H1 kit will be a great improvement but if I'm going to drop close to 600 bucks on the BLS kit, I'd want a better projector.
Also check the Lighting FAQ to see some other options.
https://ls1tech.com/forums/appearanc...hting-faq.html
The HID itself makes just as much of a difference as the projector. Put a crappy HID in there (read: DDM, Xentec, etc) you'll get mediocre output.
I purchased a high quality HID kit from The Retrofit Source too. There is no mention of what type of HID are in the BLS kit.
Morimoto H1 Version 5.0: $120
FX-R: $140
I understand the Morimoto's/Hella 60's are easier to retrofit than the FX-R's which probably played a part in BLS's decision to utilize these.
Could I have built them cheaper than paying BLS? Yes. Did I have the time to? No... Heck, I've worked on my own retrofit in my Trailblazer with the Morimotos and its not the easiest thing, at least not for me. They are STILL not done either
I'm a big advocate of DIY - I can't afford to do much otherwise! - but there are a few things that I've realized my limitations and just pay someone else to do it the right way
FX-R: $140
We could certainly get a RX, FX-R or other popular projector unit and get them to simply fit in the space for a 98-02 Firebird. Fitting an attractive shroud, forming a protective lens over the assembly and sealing up the entire unit would still be a concern. We chose the Hella 60mm unit as it performed admirably with a HID system, had favorable dimensions for the space provided and is completely sealed. In the event something leaks or fails, the projector itself can be re-utilized. Any other "open" projector would likely be ruined. Unless the system was completely sealed, the open projectors are just not a favorable option. Since projector pricing is typically in a reasonable range given the options available, this represented a very small portion of our projector choice for the 98-02 Firebird kit.
Many have performed installations using other projectors as seen in the Lighting Guide portion of the Appearance Hall of Fame. If you have the ability to fabricate and retrofit your own system together, this will always be the cheaper option. Our customers want a very significant improvement to their factory lighting and something that can be installed in their garage with the backing and support from a reputable vendor. Our current systems do just that. As you have likely seen, we are looking to revamp the current kit with the MH1 projector and have successfully done so. The only item left is to design a sealing system that will guarantee the interior will stay dry.
Our 98-02 Firebird and 93-97 Camaro kits are typically supplied with a DDM tuning HID kit unless the customer has a special preference for another supplier, including the TRS Morimoto products. All of our other kits including the 98-02 Camaro, 93-97 Firebird and all 7" H6024 kits/housings utilize TRS components including Morimoto lamps, ballasts and wiring. We place orders weekly with TRS for a number of our kits and have an excellent working relationship with Matt and his crew.
I certainly hope my comments are taken for face value and do not to come off as defensive. The intent is to provide clarity and not speculation.
If you decide to change your mind, we routinely run GP's and can also offer special discounts depending on when you are interested in ordering. Best of luck with your retrofit.
In return, I hope my comments, despite being negative, didn't come across as a bashing against your services. But understand that I was being purely objective and against sugar-coating the performance of Hella 60's an MH1's - I am merely criticizing these products; not your services. In fact, I commend a company that takes the time to "track" test their products before selling, as the reason for the long wait of the MH1's. I also commend a company that delivered such a well-written response without an ounce of bitterness.
