Painting calipers advice
It seems alot of people used the duplicolor kit, any thoughts on that, im looking long term, what does it look like, has it chipped etc.
Also, as far as prep, im reading obviously mask everything, what about cleaning and prepping the surface? Ive read steam cleaning, brake cleaner, and some other things. Anyone have any good advice on prepping the surface?
Ive never done this before, so any experience/advice would be appreciated
Thanks guys
Clean iy good with a wire brush, tape everything off anf take your time. It will come out great!
Thanks
I did them on the car, you can also use a 500 grit or so sandpaper on them if you want to knock down some of the texture too. Just use walmart plastic sacks to cover up everything else while you are working on that one part. But make sure you let it dry fully before trying to re-assemble.
Don't mean to badger you, just want to be able to replicate the results.
Yours do look great. I'm going to attempt it either this weekend or next. I guess there is no need to remove them if it can be done right by leaving them on. I think after I clean the **** out of them, I'll use some sandpaper to help remove even more of the contaminated material and give it that real smooth look.
I have never cleared mine and they hold up amazingly well. Like I said, 10 years on the others and never had to touch them. drove it from 36k to 114k and they still looked great!
Another tip I forgot to mention, Reynolds wrap is your friend on covering up things you dont want painted and making edges. I just disassembled mine on the car and propped them up or hung them to paint. No bleeding required.
Can use brake cleaner or Carb cleaner, Followed up with a non oily cleaner like Spray way glass cleaner. That is what I always use last before painting. Make sure everything is dry. Compressed air is your friend.
Yes....I am super **** retentive lolz
Last few questions for some clarity.
I decided to go w/ the G2 2 part paint. Any experience w/ it?
Calipers are staying on the car, prepping/cleaning seems to be the most important thing. What are you guys using specifically to clean? I read brake cleaner, chrome wheel cleaner, what brands? Wire brush or sponge? What are you using for clear coat? I plan on putting on TA caliper decals (I read clear coat helps them stay on), did you just use duplicolor clear coat? What type of primer also? I'm cool w/ taking my time w/ it. Just want to do it right (and powder coating is out of my budget at the moment)
Thanks
