gun metal plasti dip on my tt2.. pics
Dont scuff your wheels, because if you decide to take the Plast-Dip off at a later date... your wheels will be well scuffed. Just clean them really good with alcohol and the Plasti-Dip will stick to them nicely. I use a few thin coats to build it up a bit.
Thanks everyone for the feedback.
As for the process it was very simple. As mentioned before do not scuff up the wheels!!
First I removed the wheels from the car.
Cleaned them up with rubbing alcohol to remove all the polishing residue and so the plasti dip sticks on good.
Then I sprayed the wheels flat black plasti dip until it had a full coverage of black.
Then I sprayed the silver metalizer which is also plasti dip in rattle can, on this step the more coats of silver metalizer you add the lighter its going to be. I actually think I should have gone a little darker.
After its all dry I just peeled off the excess and that was it..
When I put the wheel back on the car and torqued them the plasti dip didn't Peel or anything.
