first time paint correction/detail
The most ive ever used a buffer for is to put wax on, so it seemed a little daunting to try and buff everything out, but i took my time and i think the results are amazing.
The car was already pretty clean, it just had a decent amount of swirls and contaminants in the clear.
i started by washing it using the two bucket method and some quality soap designed to strip wax and everything. dried it with a leaf blower and some terry towels.
After that i clayed it using meguires quick detail and clay. It was a huge pain in the *** because the clay was sitting outside of the garage and it was super cold and hard for a long time.
After the clay i used the meguires 105 on a porter cable da buffer i borrowed. i spent a lot of time on the hood, bumper and spoiler, the plastic pieces with the most swirls.
After the 105 i cleaned it up with some 205. I still wanted a little more shine so i applied a pure polish after that.
i finished up with some meguires 26 yellow wax. im a big fan of this stuff for a simple wax, it went on easily, hazed up quick, and came back off very easy.
I pulled the tape and used a little spray detailer to remove any finger prints and compound dust then snapped a cpl cell phone pics
I took these with my phone, and they definitely dont do it justice, it looks better than a factory paint job. the compound was aggressive enough to take out all imperfections and still shine up very well.
I tried to do something about the sail panel but didnt want to use something that would tear up the horrible factory paint on it. ended up just using some 205, polish, then wax. It came out pretty awesome, just not quite as glass smooth as everything else.
Overall im super pleased with it. It took me around 10 hours to complete it all, probably could have been a little quicker but the clay took forever and i went pretty slow trying not to mess anything up. Id like to take some better pictures of it to really show some detail but my camera is dead and i dont think the sun is supposed to be out here for another week.
how long did it take you? did it in a garage right? what color pad with the 105 and then with the 205?
I would also check out the Menzerna lineup. I find that line to be a little more "beginner friendly". I also really enjoy the longer working time of their compounds and polishes. The detailing industry continues to evolve at an astonishing rate. There are some pretty wild new products coming out including these newer nano coatings which are super durable. Definitely check those out as well imo.
Welcome to the sickness that is detailing.
they had just about everthing i used in stock.
no kit or anything, just followed the advice i was given about the products i bought.
i used the 26 wax because i already had it and its easy to use, same for the clay and spray detailer.
give it a try, just take your time and if you have any questions you can look online, because someone has had the same question already...lol
post up some pictures when youre done
- Go very light on the edges, creases, and corners. It's too easy to sand through the clearcoat in these areas. Luckily, there isn't much of that on the sail panel, just edges.
- Change your sandpaper often. If the surface of the sandpaper looks scraped or clogged, grab a fresh piece. If you don't, you'll just scratch up the area and have to start over.
- Keep the sandpaper and the surface nice and wet to wash away particles.
- If particles or compound build up between passes, wipe them off so that only the grit of sandpaper/compound you have selected is scratching the surface.
- For orange peel, when you start, only sand just until the dark/glossy spots disappear (when viewed dry), and no more. Then progress to the finer grits to sand out the scratches.
I'm not a pro, this is just what I've learned in all my years of sanding and polishing various things. Again, I must emphasize what an excellent job you've done with the car's paint. Definitely worth your effort.
In your times of reading forums, you ever hear anything good of Meguiars White Wax for white cars??? I picked some of that up as well...
