Shift Light In A-Pillar Vent
Old Jun 9, 2013 | 09:12 PM
xBrandonx's Avatar
Default Shift Light In A-Pillar Vent
Is it possible to get an adjustable RPM shift light in the A-Pillar vent on a Trans Am? Thanks.
Old Jun 10, 2013 | 06:29 AM
The Alchemist's Avatar
UNDER PRESSURE MOD
I have a stealth one from a guy who used to be on this site, I forget his name, but he sold them back in the early 2000's. Works great and it's nice that it's hidden and subtle till it lights up. There are 5 or 6 leds and it's bright as hell.
Old Jun 10, 2013 | 07:06 AM
smg267's Avatar
Harlan? I have been running the same one in my A-pillar for years.
Old Jun 10, 2013 | 07:08 AM
AmDWs6's Avatar
harlan i'm supposing? if you mean the one in the hole above the ac vent then yep. i'm trying to get one asap
Old Jun 10, 2013 | 07:59 AM
UNDER PRESSURE MOD
Harlan, that's who it was... brainfart on Monday morning.
Old Jun 10, 2013 | 10:26 AM
TNTramair's Avatar
i run a Harlan in that same location. its awsome. cant believe after all these years (have it since 02) thing still works like a charm. good piece. you can look up a Raptor shift light...its basically the same with a few color options and should fit in the same location.
Old Jun 10, 2013 | 11:15 AM
UNDER PRESSURE MOD
I have the very first generation Harlan light, and it has a flaw with it that when the windsheild wipers are on delay, the shift light will blink when the wipers go, but put the wipers on normal, and no issue.
Not that it's really an issue since I removed my windsheild wipers for appearance reasons, that and I never drive the car in rain. The only time the car gets wet is when it's washed.
Old Jun 10, 2013 | 11:20 AM
Firebirdmuscle's Avatar
Yes the raptor shift light fits in there. Should have no problem doing that
Old Jun 10, 2013 | 10:53 PM
xBrandonx's Avatar
Any pics / links?
Old Jun 11, 2013 | 06:59 AM
UNDER PRESSURE MOD
Originally Posted by xBrandonx
Any pics / links?
Ask and you shall recieve, although it was a quick 3 second google search.
http://harlan-engineering.com/store/...hiftlight.html
Old Jun 11, 2013 | 07:39 AM
TNTramair's Avatar
Any pics / links?
this is a raptor light...they run about $125.00 give or take a few dollars.
Old Jun 11, 2013 | 09:32 AM
xBrandonx's Avatar
Can you keep the actual vent screen on to keep it more stealth?
Thank yous, the other one is a lot cheaper though haha
Old Jun 11, 2013 | 09:58 AM
Guitar's Avatar
The way you get it in is by cutting the vented part and pushing down the defrost piece to fit it in there and get it to stay. It is a tight fit as is.
Old Jun 11, 2013 | 10:49 AM
TNTramair's Avatar
yeah..i wasnt sure if Harlan was still making them or not. id definetly go with Harlan's with out a doubt.
Old Jun 11, 2013 | 11:05 AM
BIG_MIKE2005's Avatar
I had the Harlan for a while, like mentioned worked like a charm & fit perfectly in that hole with the use of a brake booster rubber grommet. It's a tight fit but once it's in there it won't just come out. Like mentioned above, you cannot use the factory defrost vent cover as the rubber grommet required replaces it in the hole on the pillar. You will also have to disconnect that defroster hose & tuck it in the dash behind the pillar.
I set mine & then checked it in the driveway before reinstalling the pillar. Took very minimal time to get it installed.
Old Jun 11, 2013 | 03:09 PM
02TransAm/Batmobile's Avatar
I'm selling my Raptor shift light. Black casing with red LED's for 70 shipped.
