Advice on wetsanding
So far looking into starting with 2000 grit and up to 3000... Going to try the worst panel just in case... Don't get me wrong, car needs minor body work due to some very small dents and such, but that and repainting is not a luxury I have at the moment, or will for awhile. Ive got some orange peel throughout the body and looking for more of a mirror finish.
Questions is, do I have to use a rotary or is my DA enough with a good compound and polish to shine it up after? Orange and white pads from hex logic ok?
Any techniques I need to be aware of besides staying away from edges and taking it slow?
Less it better in this case to start for sure.
Just looking for some advice from people that have been there..
Thanks in advance!
BTW the thought of wet sanding make my ***** quiver so any advice will help!
Appreciate the advice. If I had known the 105 was that much better would never have used the other lol
Get a stronger polish/compound, microfiber pads, and start there. Much safer and effective way to get rid of damage when compared to wet sanding.
Wet sanding swirls/scratches out is like killing a fly with a sledgehammer.
Since you already have 105, pick up some d300 cutting compound as well and mix with the 105. It will cut down on dusting and imo makes the 105 work better. Personally ive been using m101 or menzerna fg400 with the microfiber pads.
To clean then is really easy. I typically have a bucket of water and micro-restore ready and I just clean right after im done with a pad. Using a brush in the microfiber detergent, they clean up quick. Thouroughly rinse and let dry. Ive got into a pinch a couple times and needed a pad, so I have thrown them in the dryer before on a low heat setting with no ill effects to the pad.
Not sure if you are working on OEM paint but these cars typically have hard clear coat from the factory. From my experience, UC and M105 on foam pads didn't make a dent in correcting my 02 and my dad's 02. I got the car where I wanted it using Meguiar's micrfiber pads and their D300 compound. For the deeper defects I used M105.
http://www.meguiarsonline.com/forums...rection-System
Correcting the paint as others have advised is your best bet.
Buy this kit, watch some vids(learn to prime pads correctly) and get to it.
http://www.autogeek.net/porter-cable-meguiars-kit.html
This will give you an idea with black. I put on a single stage and wet sanded with 1500. Now I know I had many coats and shouldn't burn through. I took a wool pad with Kustom compound for cutting /polishing Item #: KUS KSD-714
It will cut down to 1200 grit but works good at 1500. Talking by experience you and spray the roughest paint job, hand wet and buff into a mirror shine.
