What grit needed?
Old May 24, 2014 | 05:59 PM
IrocZTransAm's Avatar
Default What grit needed?
Quick question fellas. I had my car painted about 3 1/2 years ago. Used really cheap clear coat(omni). It started peeling about 7 months into it with a small spider crack on the rear bumper. So I wanted to start sanding it down to re-clear.
What grit would be best and wet sand I'm assuming is best. Newbie to paint so any help would be great. Yes...the search button works but was looking for help on my personal situation. Thanks fellas
Attached Thumbnails What grit needed?-20140430_163549.jpg   What grit needed?-20140430_163556.jpg
Old May 24, 2014 | 06:04 PM
Ellsworth's Avatar
that looks horrible! sorry im no help, probably a pretty strong grit to get all that off
Old May 24, 2014 | 06:10 PM
Haha yes it does. I won't even drive it like that.
Old May 24, 2014 | 08:34 PM
Ellsworth's Avatar
looks like all those black Mitsubishi eclipse's running around.
I hope you bring her back to life!
Old May 25, 2014 | 12:08 PM
I just got a really Crappy paint job. Just want to try and get it done looks terrible
Old Jun 2, 2014 | 10:03 PM
LilJayV10's Avatar
Is bad as that is you are going to have to remove everything. It'd probably use 180-220 grit and finish up with 320 and then wet 400. After that it will be ready for primer/sealer.
Old Jun 3, 2014 | 06:10 AM
stevesfbody's Avatar
What he said ^ the whole car needs to be primed. After that I'd sand it with 500, then you'll be ready for paint
Old Jun 3, 2014 | 08:44 PM
Daniel Richards's Avatar
yup, no saving the base coat, gotta start from scratch.
