Completed Wire Mod: Tutorial Inside
Old May 12, 2013 | 05:10 AM
  #141
Spartan7's Avatar
I kept the heater, A/C is gone. The air line you see controls the flapper doors in the HVAC box under the dash. All I did was take a section of the same plastic tube from a spare engine harness I had, and join it with heater tubing from the parts store to extend it.
Old May 12, 2013 | 05:47 AM
  #142
1961ba427's Avatar
Yeah...the hard vac line coming off the harness...I knew about that one. I was talking about the larger hoses going from the firewall to back behind/under the PCM. I guess they are the heater hoses, but I thought it was AC lines. Either way it gave me an idea. LOL
Old May 12, 2013 | 07:18 AM
  #143
Spartan7's Avatar
Oh, gotcha. Yea, those are the stock heater hoses. All the A/C stuff is gone. You should be able to find plenty of info on ditching A/C and keeping heat on here.
Old May 12, 2013 | 09:17 PM
  #144
1961ba427's Avatar
I plan on keeping the AC.....I even have a couple cars that previous owners deleted the HVAC system from that I may add it all back. It get's too hot down here not to have it in a daily driver. Your picture gave me an idea about possibly hiding most of the AC and heater hoses though. I know some custom hoses would need to be built, but most local NAPA or Bumper To Bumper stores can make those.
Old Dec 29, 2013 | 08:44 AM
  #145
U1D10T's Avatar
With the exposed metal should we have any issue with rust?
Old Dec 29, 2013 | 11:06 AM
  #146
silverWS.6's Avatar
You mean the hole that is cut to feed the harness through? I don't see how water or anything that could cause rust getting there. You could also give it a coat of paint with a small brush if you want.
Old Dec 29, 2013 | 11:48 AM
  #147
crimson_bird's Avatar
^that. You can certainly just brush some paint on the edge to prevent that. Also add a grommet around the edge so that the hard edge is not exposed. When I did this mod I also repainted everything, so rust was never a concern.
Old Dec 30, 2013 | 09:04 PM
  #148
Blownbayou's Avatar
Pic of mine with a few other mods done....
Old Jan 1, 2014 | 01:09 PM
  #149
redcamaro4140's Avatar
Hey buddy will doing the wire mod hurt any of the car running stuff
Old Jan 1, 2014 | 01:36 PM
  #150
TechCam97's Avatar
The only way you will hurt the car is if you half *** it and nick / cut wires that you shouldn't. Just take your time, be patient, and be sure to measure twice and cut once.
Old May 25, 2015 | 10:52 PM
  #151
Bengtson95's Avatar
what did you guys use to cut the hole?
Old May 26, 2015 | 06:45 AM
  #152
TechCam97's Avatar
1-3/4 Bi-Metal hole saw. Lowes has them and it gets the job done very well. Just did a friend's car this past weekend actually.
Old May 26, 2015 | 09:09 AM
  #153
blackbyrd's Avatar
I always thought you had to remove the fender to do this. I may be doing this soon, I relocated my passenger coils to the batterly location, and routed the wire bundle on the frame rail and Im not a fan of how it turned out. This would allow me to hide it all though I will end up with some excess wire because of it though
Old May 26, 2015 | 09:41 AM
  #154
TechCam97's Avatar
Nope, just the plastic inner wheel well.
Old May 28, 2015 | 11:19 AM
  #155
Majestic9C1's Avatar
I would also get a electrical connector disconnect tool from Lisle... makes the job a **** ton easier.. dont forget to make a diagram on a notepad of which colored wire goes where in the connector...
Old May 28, 2015 | 11:25 AM
  #156
TechCam97's Avatar
If you use a 1-3/4" hole saw, there is no need to break down the wiring connectors. They fit through perfectly!
Old May 28, 2015 | 11:27 AM
  #157
1 3/4 hole saw is overkill.. I used a 1 inch hole saw and removed the connectors.
more time consuming but I also didnt want a giant hole..
Old May 28, 2015 | 01:09 PM
  #158
Spartan7's Avatar
A paperclip is much cheaper and works just as well.
Old May 29, 2015 | 12:22 PM
  #159
LPE 403's Avatar
1 3/4 hole saws, connector disassembly....yikes, some of you guys are making a mountain out of a mole hill, lol.
IIRC, I used a 1" hole saw, drilled two holes side by side keeping in mind the width of the widest plug connector and some play room for the next connector sharing the wiring from feeding the first harness through. Blend both holes together using a die grinder so that now you have a slot. Smooth rough edges, prep with paint, modify a grommet, start feeding wires.
