Completed Wire Mod: Tutorial Inside
Old Feb 14, 2009 | 06:03 PM
  #121
domestic disturbance's Avatar
I did this mod today guys, all went well except i broke the vacume line... GRRR... If some one could pm and tell me what this vacume line controls, and what it runs to that would be great thanks alot... chris!
Old Nov 25, 2012 | 03:35 PM
  #122
KingPin1094's Avatar
Extremely skeptical about this mod. Yea it looks good but what about water spraying up there? Function > Aesthetics. Id rather have it work than look good.
Old Nov 25, 2012 | 04:02 PM
  #123
justinj's Avatar
If you look above the wheel you will see that there is a plastic fender where the wires will run over. This is a really easy mod to do, and water will not affect it.
Old Nov 25, 2012 | 04:04 PM
  #124
Blownbayou's Avatar
broke mine too... from what I read, it controls the hvac system. Panel/floor/dash vents..... cheap replacement at discount auto
later
Old Nov 25, 2012 | 04:05 PM
  #125
Blownbayou's Avatar
mine will never see rain if I can help it......
Old Nov 25, 2012 | 06:26 PM
  #126
DjinnWS6's Avatar
This looks great. I have to wait till its warmer out and I clean the garage a bit to get this done tho =(
Old Nov 25, 2012 | 09:07 PM
  #127
Thanks i see that now. Must have missed that on my first read through. Does this also mean that if i were to look up into my wheel well i would not see the wires at all? Regardless gonna be trying this soon, along with moving the TCS behind the PCM.
Old Nov 25, 2012 | 09:25 PM
  #128
buellxb12s's Avatar
I did this and the tcs relocation. Was a p.i.t.a as it fought me the entire time. Now I have a code for the cooling fans. No fuses blown, all connectors seem to be in fine so I hope I didn't mess up something with the pcm on reinstall even though it all runs fine other wise.
Old Nov 25, 2012 | 10:17 PM
  #129
Man that sucks, i hope mine goes a bit smoother. TCS still work?
Old Nov 25, 2012 | 10:51 PM
  #130
buellxb12s's Avatar
Yes it works. My biggest problem was that I was trying to do it different so no wires or hole could be seen but that didn't work. Once I did it normal and got good bits it wasn't bad. I don't want to deter anyone from doing this. I am going to pull the inner fender back off and check the wires in the connectors to make sure I didn't pull something out. Already checked to see if I missed connecting one or .something.
Old Nov 26, 2012 | 02:05 PM
  #131
Spartan7's Avatar
I did mine that way, no hole visible.
http://ltxtech.com/forums/showthread...d-with-a-twist
Old Nov 27, 2012 | 06:37 AM
  #132
maxplusten's Avatar
Sold, im gonna start on it this weekend. My main problem was always i couldnt figure out what to do with the fusibles and the battery distribution terminal, you deffinatly got it figured out spartan7... thanks for the idea!
Old Nov 27, 2012 | 11:04 AM
  #133
buellxb12s's Avatar
That's exactly what I was going for and if I would have seen that before I starred I would have done it that way.. I tried placing mine under the pcm but the wires were to tight. If I had planned ahead of time would have done extensions like you had there.
Old Nov 27, 2012 | 02:28 PM
  #134
Spartan7's Avatar
Just one thing I should add about doing it the way I linked. I found it difficult to fit the inner fender back in with the harness attached where it was. I relocated it to further inside the wheel well, right behind the lip of the big flat part you see in the pics. There was enough slack to run it that way, and the inner fender fit great after that.
Old Mar 18, 2013 | 03:01 PM
  #135
3YLSYKR's Avatar
As nice as this is and looks, it's not worth it to me to have all those wires exposed like that to elements from the tire and anyone who wants to mess with it. I rather leave it secure under the hood.
Old Mar 25, 2013 | 01:04 AM
  #136
Khaalathas's Avatar
looks much cleaner after nice write up too
Old Mar 26, 2013 | 06:08 AM
  #137
fastcars95's Avatar
I'm going to try this soon. Looks pretty straight forward
Old May 10, 2013 | 01:59 PM
  #138
LS1again's Avatar
I cannot for the life of me understand how people still think this way after everyone else debunking the belief that anything is exposed to any more of the elements than it already is under the hood. Unless you don't have a fender liner for some reason, then there is nothing to worry about. WTF
Old May 11, 2013 | 01:50 AM
  #139
stone4779's Avatar
+1
I drove my 99 through rain hail snow sleet whatever for years and I never had I problem.
I would say that if the wires were going to be problematic in my lifetime, they would have already.
Just insulate the wires more if you're that worried. I mean if it's WATERPROOF and AIRTIGHT it isnt going to be a problem.
Old May 11, 2013 | 08:20 AM
  #140
1961ba427's Avatar
Default Wire-tuck mod
I never noticed in your wire tuck pics that it looks like you kept HVAC and re-routed the hoses for the heater and A/C. Are there any more pictures or info on that part of your engine bay cleanup? Thanks, Jason
