Firebird LED Fog Light Housings
Depending on depth I would wager to guess you could still use the factory housings you would just need a new way to mount them since the cross member looks like it is gone as well judging by what I can see in that pic
the biggest thing you will have to adjust to is that no matter what you choose the housing will likely set closer to the surface of the bumper.... might be cool if you could borrow a housing form something with more curve so it could follow the contour of the bumper should you have to make them set flush?
How much depth do you have available before you are on your intercooler?
UNDER PRESSURE MOD
judging by the pic in your sig, It looks like your fog light holes in your bumper are not quite as deep as they used to be.
according to the website the light housings that Vip1 used are 2.6 to the physical end of the housing, but the tab that is used for angle adjustment makes them about 3.4 inches deep. Assuming the measurements were in MM and my conversion was correct
judging by that pic again, it seems you may have some addition depth on the outer part of the opening where the end of you intercooler opens up to the dead space leading to the radiator support. Its possible you may be able to turn these on there side (which would make the adjustment of side to side as opposed to vertical) and secure the bracket to something in that area as well, but I wouldnt guarantee that assessment.
most of the fog lights that are aftermarkets should show physical dimensions if you start digging into other options that might fit your car. Than again if you dont mind cutting up something you just bought, it looks you could get some additional clearance if you ground down the raised venting on the housing (which is typically for ventalation in electronic components that generate high heat) but im not sure what help they would offer for the lights in that area anyway. You could gain ... well loose some depth of the actual housing especially if you were froggy enough to remove the to adjustment tab and come up with an alternative since you have to make a bracket reguardless.
food for thought, especially if you like this design
Copy & Paste Moderator
Originally Posted by The Alchemist
You are absolutely accurate on all your assessments. I have about 2.5 to 3" from the front of the bumper to the intercooler.
Why do you want to rotate them? That won't change available clearance.
Also, any good fog light housing will have a low flat wide beam.
#33
Does that explain what i was saying better?
#34
I saw similar threads on Jeep forums about installing these on other model Jeeps. However, I didn't see any exact measurements about width and depth. For example, the 3 1/8" hole saw recommendation in that thread might be the rough size of the cup/body, but is that with or without the plastic tabs that stick out the sides? One thread they removed the tabs and then shimmed to fit the hole they cut. What is the width of the face since it is wider than the cup/body? My guess is that it may be close enough, but I'd like confirmation and I still need to know the depth.
#35
I no longer run a front plate, so it gets the majority of the airflow through that opening. The fog light openings actually let in a very insignificant amount of airflow.
https://scontent-lga1-1.xx.fbcdn.net...ea&oe=56005472
all of my suggestions were based off of his bumper and modifications he has made behind it which share non of the stock mounting locations
you have not to mention you have a formula bumper so they mount completely different as well as use a different bracket. In OE orientiation the TA foglights bracket doesnt set entirely behind the housing, instead it sets under it with a long tab which you use to bolt it to the impact bar.
From what I remember, although the mounting bracket is different, they both use the same Fog Light Housing.
Using a similar bracket design rotating the mounting location on their side would allow for a bracket that could slip past the intercooler as it doesnt fill all the backspace behind the foglight opening. then it could be tied to whatever is left in that area since the main impact bar has been removed. At least that is the first place I would start. Some modifications to the housing would allow for less depth which is what I pointed out as well.
All the above being done as you pointed out the cutoff would be vertical as opposed to horizontal, which is why I brought up rotating the internals to level the cutoff back out.
Thanks.
#36
typo on my part about the formula bumper I ment to say "not tomention you have a formula". I edited it quite a few times so I didnt come across as a condescending *** but I think I failed.
i was trying to say they are different ( i used to have the firebird bumper on mine) . the TA bumper has nothing to mount the lights to its just a hole, the lights actually mount to the bottom of the impact bar, so when you pull the bumper off the fogs are still attached to the car. Not sure on the housings though i would assume they are the same, but the bracket isn't and instead of being behind the housing the bulk of it actually sets under the housing, which is where the idea to turn the housing came from as i think that would clear the intercooler, minus the depth issue
#37
I understand what you are saying, I'm just pointing out that it may be possible to make something to attach to the bumper cover itself even though that isn't how it was from the factory.
