Door Molding Delete
Old Jun 27, 2004 | 03:00 PM
James Creasy's Avatar
Default Door Molding Delete
This is a picture of my car with the door molding off, tell me what you think!
http://www.cardomain.com/member_page...65_10_full.jpg
Old Jun 27, 2004 | 04:55 PM
PongoX11's Avatar
You need to upload those to a webpage... or edit your post and click on attachements and upload it to the post
I am sure it looks great though--really cleaned up the looks of my car when I did it
Old Jun 27, 2004 | 05:09 PM
BADFNZ-383's Avatar
im sure it looks good. i took mine off, and i think it looks much better
Old Jun 27, 2004 | 05:15 PM
1BADFNZ's Avatar
Yeah I removed my body side molding an pinstripes and it looks 100x better
Old Jun 28, 2004 | 04:58 PM
TTT... fixed picture problem
Old Jun 28, 2004 | 05:01 PM
Danny2tek's Avatar
Looks just like mine!
Old Jun 28, 2004 | 05:46 PM
Ru2n00n3er's Avatar
Ok I've got a question on this. Are you guys just ripping the molding off the car? Is there paint already underneath the modling that matches your car? Wouldn't ripping it off scratch that paint if it is there?
I'm interested in doing it, but just want to know if you guys had to repaint your doors after it came off, how involved of a process it was, etc.
Old Jun 28, 2004 | 07:38 PM
ratio411's Avatar
It's just held on by 2 sided tape...
Very strong 2 sided tape though.
Yes there is paint under there. If you don't use anything sharp to remove it, the paint there will be cleaner than the rest of your car.
I used adhesive remover and quite a bit of 'elbow' to get the tape off the car.
Then I had to polish the car to get the newly exposed paint to blend with the rest of the car.
It's a good mod.
Dave
Old Jun 28, 2004 | 09:13 PM
Black 98 T/A's Avatar
heat it up with a hair dryer and use dental floss to remove it.
Old Jun 28, 2004 | 09:15 PM
Ru2n00n3er's Avatar
Polish as in meaning what?
Old Jun 29, 2004 | 12:10 PM
Ru2n00n3er's Avatar
Can people post up pictures of their cars with the door molding taken off? I'm more interested in what Camaros look, specifically black ones. I want to see what it looks like before I start ripping stuff off my car.
Old Jun 29, 2004 | 01:09 PM
I don't know what Camaros look like but I'd like to see that also. And as far as taking the molding off it was easy. 1) Heat the molding with a blow dryer, 2) Use fishing line to pull it on off , 3) Use WD40 to get the adhesive off. I also sprayed WD40 on my cars door and used a T-shirt and "Elbow Greese" and the stuff came right off.
Old Jun 29, 2004 | 01:43 PM
1BADFNZ's Avatar
I didn't have to use a hair dryer. I waited till like 2 in the afternoon after the sun had heated it up and it pulled right off... no dental floss or nothing. If you're good and take your time most if not all the adhesive will stick to the molding instead of the body.
Then clean it up and good to go.
Check out my car page.
Old Jun 29, 2004 | 02:03 PM
mako22's Avatar
don't be afraid - it turned out to be a lot easier than I thought. My car is an 02 so maybe the tape was still fresh but the molding pulled right off without much problem at all. Just go slo and have some goo-gone on hand for the leftover adhesive....
pics you say?
Old Jun 30, 2004 | 05:20 PM
ratio411's Avatar
Ru2n0n0er3
It's the kind of mod that nobody really notices until you
point it out. It's a cleaner look if you know what you are
looking at, but it's not such a big difference to be scared of
doing it.
I have a bunch of these subtle mods to my Z. It looks
more or less stock, but I point out one or two little things
to folks and they 'get it'. Then they start noticing more
and more little things.
Dave
Old Jun 30, 2004 | 05:27 PM
Ru2n00n3er's Avatar
Yeah it wouldn't make all that much difference in the line of the car, becaure there is still the crease in the body panel itself in the same spot.
Old Jun 30, 2004 | 06:32 PM
f-bodman's Avatar
It looks good enough that it makes me want to take mine off.
Old Jun 30, 2004 | 11:58 PM
Unforgiven1's Avatar
I'm with ya on this one. Especially a black car. I don't think it would make a big enough difference to matter. MAKO do you have any before pics with the moldings on? Oh and while I have your attention, I don't know if it's just cause my computer screen is darker or what but man, I never even realized your hockey stripes they are so subtle but I kind of like that. Anyway...
Justin
Old Jul 1, 2004 | 08:39 AM
Derek98z's Avatar
especially Firebirds, but all F-bodys should remove their moldings.
Old Jul 2, 2004 | 10:15 AM
Snootch's Avatar
I definately like it better with them removed... I took mine off with a junk plastic credit card (old busch gardens pass) and I sharpened the edge on the bench grinder. I documented the process here: http://www.sounddomain.com/memberpage/252862/5
