Steering wheel gone bad, help.
Old Sep 19, 2017 | 06:36 PM
maxgee's Avatar
Default Steering wheel gone bad, help.
Steering wheel broke while I was trying to remove it to install an aftermarket one; see the video for the current condition and provide information you may know that can help. Thank you.
Old Sep 20, 2017 | 12:41 PM
95sscamaro's Avatar
id use a cutoff wheel if you can get it i there, make a cut on top and bottom of the nut (but don't go all the way down to the steering shaft) then use a flat chisel and hit it with a hammer a couple of times. This should crack it the rest of the way and fall off. Think of it as removing a bearing race or look that up.
Old Sep 20, 2017 | 12:47 PM
Deguila's Avatar
Have you tried a nut splitter, much safer than a cutting wheel. No danger of beggaring up the shaft. Good luck bud!
Old Sep 22, 2017 | 03:16 AM
The Batman's Avatar
Dremel tool with a small cut off wheel.
Old Sep 24, 2017 | 10:09 AM
96lt1m6's Avatar
As stated above, a dremel tool with a cut-off wheel would be the best choice for this situation.
Old Sep 24, 2017 | 11:48 AM
maxgee's Avatar
Got it off and new one on.
Old Oct 8, 2017 | 04:52 PM
Phoenix'97's Avatar
Looks really nice! I am glad the swap was a success.
Old Oct 8, 2017 | 09:48 PM
cancam99ss's Avatar
glad to see you are still around.. still living down south in homestead? id love to see the c5...
