Sponsored by: DashLynx
LS1 fuel rail covers
Old 11-08-2023, 11:12 AM
WS6Y2KTA's Avatar
Default LS1 fuel rail covers
Are there blank or Pontiac specific LS1 fuel rail covers? I like the clean look, but trying not to install Corvette covers. TIA!
Old 11-08-2023, 02:00 PM
MuhThugga's Avatar
There are GTO fuel rail covers, but they say "GTO" on them. You can grind down the lettering and do whatever you'd like. I did that for my dad's Impala SS.
Old 11-14-2023, 10:55 AM
ghardester's Avatar
The answer is no, there are not LS1 specific fuel rail covers. You can make them out of LS1 Corvette covers by shortening them, filling in the Corvette part, sand and paint. I did not make these, I bought them.
Old 11-15-2023, 10:00 AM
WS6Y2KTA's Avatar
Thankx for reply. Odd, ya think someone would be selling 'em.
Old 11-15-2023, 02:03 PM
jybravo70's Avatar
Afterthoughts Auto used to sell these but not for years. I picked up a pair of Corvette LS1 covers and will be cutting, filling, painting to use for my car. The hardest part is finding covers with all the bolt clips still intact and figuring out how much to cut.
The following users liked this post:
blackbyrd (11-15-2023)
Old 11-17-2023, 08:53 PM
Cajun ELESS-ONE's Avatar
I did this project as well. Cut out where the fuel lines go and some other small areas to clearance them. Sand it, fill in the Corvette part, use adhesive promotor for the plastic. I used high build primer from a rattle can and matching paint for rattle can as well. I would highly suggest to put some kind of heat reflective tape or something on the under side. The paint started bubbling after a couple of heat cycles when on the motor because the headers.
Old 11-18-2023, 02:08 PM
ghardester's Avatar
That is where I bought mine. They were rediculously cheap, like $120 bucks. They are very well made, but whoever was making them quit.
Old 11-18-2023, 03:59 PM
LS1 TJ's Avatar
Don't know if this would work for you but I've been using LS3 coil covers. Then I fab a piece of 1/8" flat stock to cover up the Corvette logo. Weld in three 10-24 studs into the 1/8" to hold it to the cover. Paint the insert black. Then get some graphics from a local graphics place. See pic.
transam5.7lt1 (11-21-2023)
Old 11-21-2023, 09:28 AM
transam5.7lt1's Avatar
I remember there were companies that used to sell aftermarket LS1 FRC, kind on par with OEM Corvette pieces pricewise, so I guess most opted for OEM. I myself have been sporting OEM red Corvette LS1 FRC in my Trans Am.
Quick Reply: LS1 fuel rail covers
