polishing parts
Old Sep 21, 2004 | 04:46 AM
michelinss's Avatar
Default polishing parts
what parts on my ss can be polished is it just the aluminum parts or can other metal parts be polished also which parts are aluminum
Old Sep 21, 2004 | 06:21 AM
JackZ28's Avatar
Anything metal can be polished. Some of the harder metals just require a little more elbow grease! Everything metal under the hood can be polished to a brilliant luster. Good luck.
Old Sep 22, 2004 | 08:41 PM
michelinss's Avatar
what is the easiest way to do it i have a dremil what else do i need what kind of polish do i need what kind of attachments do i need
Old Sep 22, 2004 | 08:49 PM
5POINT7's Avatar
You should pm that one guy with the black Camaro w/ polished everything underhood and under chassis. He's got chrome zr-1s and is procharged in his sig. Does anyone know who I'm talking about?
Old Sep 22, 2004 | 08:59 PM
Danny2tek's Avatar
Todd2001SS...........................
Old Sep 22, 2004 | 09:16 PM
5POINT7's Avatar
Yep, that's him.
Old Sep 23, 2004 | 11:53 AM
y2k_ta's Avatar
'Bird Director
From: Central Indiana Honors: 4th grade spelling bee contestant
I'd like to polish my air conditioner condenser. I've seen a few cars that have done that before, and it looks pretty cool.
Old Sep 25, 2004 | 07:15 PM
JasonWW's Avatar
Dremel makes a polishing kit with compound and wheels etc... It is pretty cheap, also. I just started trying different wheels and experimenting. So far I have polished my MAF housings. Came out real well. TB is next on the list.
You might give that a try.
Old Sep 25, 2004 | 11:42 PM
Todd2001SS's Avatar
Tech Addict
Mustang5.Ohater...Thanks.
Here is a write up I did that should help....
How to Polish
michelinss what parts on my ss can be polished is it just the aluminum parts or can other metal parts be polished also which parts are aluminum
Metal parts are hard to polish and they will rust if not clear coated.
Here are some parts I just polished that are metal...
After...(I did not detail the washers, they will not be seen) These are the sway bar brackets ect..
Before...
Old Sep 25, 2004 | 11:45 PM
screamin' 85 z's Avatar
EXCELLENT write-up...(very nice looking results too!)
Old Oct 4, 2004 | 02:58 PM
PewterNHRA2001's Avatar
i guess this question will fit with this topic, would i be able to use like polishing compound (the stuff found down the ''car care'' isle at any store) with the polishing attachments on a dremel to polish metal and such, or do i need to get the polish that dremel sells, or is there something else i can get?
Old Oct 4, 2004 | 04:16 PM
Todd2001SS's Avatar
Tech Addict
Some polishing compound is really metal cleaner. Make sure you use White Rouge & Tripoli. The surface contact area on a dremmel will make it hard to polish larger parts also the wheels get dirty and you have to throw them away very often.
Old Oct 4, 2004 | 04:51 PM
whats white rouge and tripoli, and where do i get it from?
Old Oct 4, 2004 | 09:21 PM
JasonWW's Avatar
They are polishing compounds. The local hardware store should carry them.
Old Oct 4, 2004 | 09:53 PM
Todd2001SS's Avatar
Tech Addict
Here is where I buy mine from...
Eastwood
