Debadging
Old Nov 3, 2004 | 03:20 PM
KCamaro's Avatar
Default Debadging
What would it take to remove the Z-28 labels from a car? I'm thinking of debadging the car to keep from people recognizing it as a V-8 and to attempt to keep street racing challenges to a minimum.
Old Nov 3, 2004 | 03:22 PM
superchannelkev's Avatar
fishing line.. some adhesive remover for the residue..
Old Nov 3, 2004 | 03:23 PM
KCamaro's Avatar
Good idea, I figured a razorblade would be too dangerous on the paint.
Old Nov 3, 2004 | 03:29 PM
keep that blade away from your paint!!!
Old Nov 3, 2004 | 08:29 PM
02blackws679ta's Avatar
what about to door molding? i think im finally going to remove mine but i havent seen any 'write-ups' or threads about it in a long time
Old Nov 3, 2004 | 08:33 PM
same deal... i've been debating it but I always hit this one trash can in my garage... some people suggest heating it up with a heatgun or hair dryer and then using the fishing line.. so there is less residue on the paint.. you might also want to use some sort of polish afterwards to make sure you still got all the shine!
Old Nov 4, 2004 | 06:39 AM
JackZ28's Avatar
PLEASE
Old Nov 4, 2004 | 07:20 AM
Angus's Avatar
I too want to take the door trim off the car. I have taken the RK Sport stripe kit off of my Camaro as well as my Z28 badges and all I did was pull them off and went to Wal-Mart and bought some Oops(i think that is the name of it) which will remove the sticky stuff as well as sap from pine trees off of the car.
Old Nov 4, 2004 | 08:41 AM
camar0guy's Avatar
a writeup? just heat it up and pull i toff, then get rid of the sticky stuff and u done....
Old Nov 4, 2004 | 08:47 AM
TNC_LS1's Avatar
I Did Mine With Dental Floss And Goo Gone The Goo Gone Sucks Dont Use It. I Rubbed For Hours And Finally Got It Off
Old Nov 4, 2004 | 02:57 PM
67SS&99SS's Avatar
Dental floss and this cleaner called fantastic. Any deagreaser should work. I just removed the Z28 emblems off of my uncles 94 Z and put 1970 Z emblems on it. It looks way better. Hopefully I'll have some picks up by this weekend.
Old Nov 4, 2004 | 03:50 PM
TAdriven98's Avatar
i used bug and tar remover and also wd40 works good
Old Nov 4, 2004 | 04:00 PM
RollTideTA's Avatar
Regular old rubbing alcohol will remove any of the sticky residue that decals and emblems might leave. Just clean and re-wax the small area when done.
Old Nov 5, 2004 | 12:09 PM
kerryt1's Avatar
Heat gun, followed by 3M adhesive remover (wal-mart).
Old Nov 5, 2004 | 01:13 PM
EviLS1's Avatar
After the fishing line I used a blow dryer, a cup of hot water, and a rag.
Old Nov 5, 2004 | 01:18 PM
Snootch's Avatar
http://www.sounddomain.com/memberpage/252862/5
Old Nov 6, 2004 | 09:19 AM
SWEET 02's Avatar
does any one have any pics with camaros that have the trim removed???
Old Nov 6, 2004 | 11:00 AM
6']['9's Avatar
dental floss & 3m Adhesive remover from local auto parts store.
Old Nov 7, 2004 | 10:27 PM
02blkragtopz's Avatar
OK this may sound stupid to take the glue off but it works without the mess of "goof-off" or "WD-40". Peanut Butter! Sounds like bs but it works. Put it on let 'er sit for a few.........and wipe it off. Now, it does take a little more elbow grease but, it beats the hell out of rubbing FOREVER to get off the two afore mentioned. I mean yeah, they get the glue off but then......what the hell takes them off! This is what I'll be using when I take mine off this winter. jmo
Door molding eh.........interesting
Old Nov 7, 2004 | 10:37 PM
ddelallata's Avatar
